Bug Fixes and Enhancements in 4.2.18 Official
Release Date
- 2014.10.30
Known Issues
- None
Important Notes
- Due to a major SSLv3 vulnerability (POODLE), all SSLv3 functionality is disabled. On the 994i series, TLS1.0 is now the default protocol. On PRO series, you can choose up to TLS 1.2. Please make sure all outbound connections continue to work using TLS1.0
- For units with Z-Wave capabilities, backing up and restoring a backup corrupts Z-Wave configuration and thus you might need to exclude/include all devices afresh
- Unfortunately - and due to code space limitations on ISY99 Series - we will no longer have any firmware releases for ISY99i Series
Bug Fixes
[Z-Wave] System hang in case at startup there are Z-Wave nodes but Z-Wave module was not enabled
[MOD-ELEC] Fixed the granularity issue for wattage for Brultech/GEM
[Dashboad] Fixed Self Signed Certificate exception on Java 1.8
Enhancements
[Z-WAVE] Minor changes for certification - NO fucntional changes
[sEP1.1b] Preparations for SEP1.1b Certification - NO functional changes
[iNSTEON] You can now set Zone 8's mode (Pump/Normal)
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.18
-- WSDK 4.2.18
***UDAjax/HAD is now included in WSDK
Bug Fixes and Enhancements in 4.2.17 RC7
Release Date
- 2014.10.21
Known Issues
- None
Important Notes
Bug Fixes
[Z-Wave]
- Fixed phantom multilevel sensor readings
- Support for SUC/SIS in network (although ISY cannot be a SUC/SIS)
- Show node details/link/network information in the event viewer
- Repair Links now also adds back missing links to ISY
[OS]
- Better handling of Query All for large installations
Enhancements
[OS] Disabled SSL. TLS1.0 is now the default
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.17
-- WSDK 4.2.17
Bug Fixes and Enhancements in 4.2.16 RC6
Release Date
- 2014.
Known Issues
- None
Important Notes
Bug Fixes
[Z-Wave]
- Queue heal, repair links, and query for when a device wakes up (for battery devices supporting wakeup)
- Possible fix for intermittent crash
[iNSTEON]
- Do not query door sensor at startup
- Allow door sensor to be queried in programs (most useful after receiving a message from door sensor)
Enhancements
[ADMIN-CONSOLE] Added copy to clipboard button on the event viewer
[OS] Added support for Vantage Point & UDI Portals
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.16
-- WSDK 4.2.16
Bug Fixes and Enhancements in 4.2.15 RC5
Release Date
- 2014.09.21
Known Issues
- None
Important Notes
Bug Fixes
[MOD-CLIMATE] Fixed invalid unit of measure for pressure
[MOD-CLIMATE] Fixed intermittent issues with stations not showing up
[MOD-SEP] Fixed special characters causing the message truncation
[uD-AJAX] Fixed SEP pricing and metering format issues
[OS] Fixed System reboot in case of corrupted Z-Wave packets
[uI] Fixed File Chooser issues on MAC
[Z-Wave] Some Z-Wave databases unnecessarily saved to file system when device is queried
[iNSTEON]
- Fix LED brightness option for 2663-222 (1-50% was equal to 51%-100%)
- Set weekday when synchronizing clock for Templinc Thermostat
Enhancements
[Z-Wave]
- Support for Sensor Alarm
- Warn of delayed commands during network heal
- Nicer logging of Z-Wave commands
- Support for FortrezZ MIMOLite
- Support IRIS Garage door controller
- Added option to protect/unprotect network key
- Added Repair Links command to remove dead links from devices
- Added more options for Schlage BE469 lock
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.15
-- WSDK 4.2.15
Bug Fixes and Enhancements in 4.2.10 RC4
Release Date
- 2014.08.22
Known Issues
- None
Important Notes
Bug Fixes
[Z-Wave]
- Dump details of Z-Wave device (right+click Node -> Z-Wave-> Show Node Details in Event Viewer)
- Added detailed log entries whenever a Z-Wave node is added (to test for phantom nodes)
[iNSTEON]
- Support for OutletLinc 2663_222: fixed LED brightness in Admin Console
[ELK]
- Out of memory error
Enhancements
[Z-Wave]
- Added support for Z-Wave standard alarms
- More certification related enhancements
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.10
-- WSDK 4.2.10
Bug Fixes and Enhancements in 4.2.8 RC3
Release Date
- 2014.08.01
Known Issues
- None
Important Notes
Bug Fixes
[MOD-CLIMATE]
- Climate Conditions not getting updated
- Cannot save an empty location ID when disabled
Enhancements
[MOD-ENERGY]
- Increase granularity for energy meter channels
[iNSTEON]
- Support for OutletLinc 2663_222: added LED brightness
[Z-Wave]
- ISY can now be included as a secondary controller into an existing network and accessed as a secure device
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.8
-- WSDK 4.2.8
Bug Fixes and Enhancements in 4.2.7 RC2
Release Date
- 2014.07.25
Known Issues
- None
Important Notes
Bug Fixes
[OS]
- Random reboots (DNS related)
[MOD-IRRIG]
- Revert: reset irrigation requirement if
[Z-Wave]
- Removing a failed node from the Z-Wave dongle
[sEP]
- Fixed optin/opt out issues
- Fixed price/tier issues
- Install Key is now generated/retrieved from the Zigbee dongle
Enhancements
[iNSTEON]
- Support for Plugin Dimmer (Global) 2632_422, 2632_432, 2632_442, 2632_522
- Support for Plugin Relay (Global) 2633_422, 2633_432, 2633_442, 2633_522
[Z-Wave]
- Certification related enhancements
Developers
- Updated 4_fam.xml for Z-Wave devices and categories
- Updated Z-Wave Developer documentation
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.7
-- WSDK 4.2.7
Bug Fixes and Enhancements in 4.2.5
Release Date
- 2014.06.27
Known Issues
- None
Important Notes
Bug Fixes
[MOD-CLIMATE]
- Moving to HAM production servers
- Some UI Values not updated when going between stations
[uI]
- Batch buttons & menu items not showing up (possible fix)
[OS]
[sEP]
- Fixed the issue where multiple prices were running at the same time
Enhancements
[TLS] - Added "All" to the list of Ciphersuite strengths
[Z-WAVE]
- Yale Door Lock Schedules
- Schlage Door Lock Options
- Yale Door Lock Options
Developers
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.2.5
-- WSDK 4.2.5
Bug Fixes and Enhancements in 4.2.4
Release Date
- 2014.06.11
Known Issues
- Doesn't include support for Yale schedules; still a couple of bugs which requires Yale
Important Notes
Bug Fixes
[MOD-IRRIG]
- Evapotranspiration not updated properly
- Values not reset after changing configuration
[MOD-CLIMATE]
- Now include all stations (28K)
- Forecast values were not being updated properly (the filter was not returning the forecast for tomorrow)
[uDI AJAX]:
-- Includes 24hr forecast
Enhancements
[MOD-CLIMATE]
- Last successful updated timestamp for climate module: {C}viewtopic.php?f=7&t=14955{C}
- Added Today's (24 Hour) Forecast
[Z-WAVE]
- Supports changing access codes for all the door locks
- Supports schedules for Kwikset
[ZIGBEE]
-- Can now configure ISY's time from the meter
Developers
[MOD-CLIMATE]
Deprecated:
UD_INET_CTL_CLIMATE_WIND_SPEED_AVG 12
UD_INET_CTL_CLIMATE_GUST_WIND_DIRECTION 16
UD_INET_CTL_CLIMATE_HUMIDITY_RATE 7
UD_INET_CTL_CLIMATE_PRESSURE_RATE 9
UD_INET_CTL_CLIMATE_WIND_DIRECTION_AVG 14
UD_INET_CTL_CLIMATE_LIGHT_RATE 19
UD_INET_CTL_CLIMATE_RAIN_RATE 20
UD_INET_CTL_CLIMATE_RAIN_RATE_MAX 21
New (24 Hour/Today’s Forecast):
UD_INET_CTL_CLIMATE_TEMPERATURE_AVG_TODAY 42
UD_INET_CTL_CLIMATE_TEMPERATURE_HIGH_TODAY 43
UD_INET_CTL_CLIMATE_TEMPERATURE_LOW_TODAY 44
UD_INET_CTL_CLIMATE_HUMIDITY_TODAY 45
UD_INET_CTL_CLIMATE_F_RAIN_TODAY 46
UD_INET_CTL_CLIMATE_F_SNOW_TODAY 47
UD_INET_CTL_CLIMATE_COVERAGE_TODAY 48
UD_INET_CTL_CLIMATE_INTENSITY_TODAY 49
UD_INET_CTL_CLIMATE_WEATHER_CONDITION_TODAY 50
UD_INET_CTL_CLIMATE_CLOUD_CONDITION_TODAY 51
UD_INET_CTL_CLIMATE_LAST_UPDATED_TS 100 //last updated timestamp
Developers Links
-- URL for Web Services: {C}http://www.universal-devices.com/developers/wsdk/4.2.4{C}
-- WSDK 4.2.4
Bug Fixes and Enhancements in 4.2.3
Release Date
- 2014.06.02
Known Issues
- None
Important Notes
Bug Fixes
[OS]
-- Unreliable/Intermittent DNS operations
[Z-WAVE]
-- Could not remove a device from a multi protocol scene ({C}viewtopic.php?f=25&t=14393&p=114733#p114733{C} )
-- BE369/FE599 Schlage Access Code events now sent consistently
-- Lock button in Admin Console for FE599 Schlage
[iNSTEON]
-- Venstar Heat/Cool state was set to Heat instead of Off
-- Remove Insteon controller from scene containing non-Insteon responders
-- Fixed sync clock program action for Thermostats
-- Options dialog for Insteon devices occasionally caused Admin console to hang
-- Persist D2D status icon setting
[uDI AJAX]:
-- Fix for camera config file save in IE (Hopefully)
-- Fix for camera requiring basic auth in IE
Enhancements
[iNSTEON] Added CLIHUM to the default list of properties for thermostats
[MOD-CLIMATE]:
- Support for HAM Weather
- Additional climate attributes
-- Coverage (i.e. chances, areas of, ...)
-- Intensity (i.e. light, heavy, ...)
-- Weather Condition (i.e. hail, rain, showers, ...)
-- Cloud Condition (i.e. clear, cloudy, ...)
- Support for the following forecasts:
-- Average Temp Tomorrow
-- High Temp Tomorrow
-- Low Temp Tomorrow
-- Humidity Tomomrrow
-- Wind Speed Tomorrow
-- Gust Speed Tomorrow
-- Rain Tomorrow
-- Snow Tomorrow
-- Coverage Tomorrow (i.e. chances, areas of, ...)
-- Intensity Tomorrow (i.e. light, heavy, ...)
-- Weather Condition Tomorrow (i.e. hail, rain, showers, ...)
-- Cloud Condition Tomorrow (i.e. clear, cloudy, ...)
[Z-WAVE]
-- Z-Wave First Alert smoke/co alarms
-- Show Z-Wave dongle bootloader version
[iNSTEON]
-- Door Sensor heartbeat/battery
[ZIGBEE]
-- Support for upgrading Zigbee firmware (from dashboard)
-- Support for Rejoin on SEP
Developers
- Additional climate events for forecast: udevnts.xsd
- Support for Web Sockets ... please refer to developer links
- UDAjax support for forecast data
Developers Links
-- URL for Web Services: {C}http://www.universal-devices.com/developers/wsdk/4.2.3{C}
-- WSDK 4.2.3
Release Date
- 2014.4.18
Known Issues
- None
Important Notes
Bug Fixes
[OS] Fix possible errors related to status conditions
[OS] Add more tracing to event viewer for status conditions
[Z-WAVE] Log unrecognized kwikset alarms
[Z-WAVE] Add On/Off buttons in admin console & programs for more switches
[Z-WAVE] Setpoints in conditions for Z-Wave thermostats
[Z-WAVE] Fixed values for some Z-Wave program conditions (e.g. Aeon multisensor temperature)
Enhancements
- Same as 4.2.0
Developers
- Same as 4.2.0
Developers Links
- Same as 4.2.0
-- URL for Web Services: {C}http://www.universal-devices.com/developers/wsdk/4.2.0{C}
-- WSDK 4.2.0
Bug Fixes and Enhancements in 4.2.0
Release Date
- 2014.4.13
Known Issues
- INSTEON/Brultech Programs based on status may not work
Important Notes
Bug Fixes
[OS] - Time change status updates were not being published
[Zigbee] - Too many zigbee status update events were being published
[TLS] - System hang in a very rare case: TLS1.1, 2048, SHA1, AES256
[bRULTECH] - Trigger values up to 10,000 for channels
[iNSTEON] - Micro Module dimmer options were not accurate
[iNSTEON] - Hidden door sensor reporting as triggerlinc
Enhancements
OpenADR 2.0b Certified
[ADMIN CONSOLE] Membership Tree is now expanded by default
[iNSTEON] Support for Refurbished IOLinc
[NETWORK] UPnP is now selectable (default is Off)
[ZIGBEE] Retrieve the firmware version of the Zigbee radio
[ELK] Use ISY txId when sending status to Elk
[uI] Added Event Viewer Button to Admin Console
[ZWAVE]:
- Upgrade Z-Wave firmware to 4.55 Static Controller (See below)
- Schlage BE469NX door lock (powered deadbolt)
- Fortrezz water valve
- Aeon Multisensor
- PMC40
- Much more generic device support
- Fixed Deadbolt Jammed/Unknown formatted status for REST interface
- Support Celsius in Thermostats
- Query/Edit Raw Z-Wave device configuration values
- More Driver Controls
- Network Heal
- Support uom/precision for Z-Wave action values and events
- Better formatting of values
- Aeon Multisensor
- PMC40
- Network Heal
Developers
- OpenADR 2.0b full support for registration, report, and opt
- GetNodeInfo, GetNodeInfoKey
- SetConfigParam
- QueryConfigParam
- FirmwareUpgrade
Developers Links
-- WSDK 4.2.0
Bug Fixes and Enhancements in 4.1.2
Release Date
- 2014.1.14
Known Issues
- None
Important Notes
Bug Fixes
[iNSTEON-AC] - Fixed the system hang when removing multiple nodes from a scene
[iNSTEON-AC] - Copy Scene attribute ignores keypadlinc sub button ({C}viewtopic.php?f=27&t=13074&p=102285&hilit=marvel#p102285{C})
[iNSTEON] - KPL backlight now turns off when 0/0 is issued ({C}viewtopic.php?f=27&t=11048&start=45{C})
[iNSTEON] - Fixed Fanlinc dimmer status possibly being updated incorrectly when Fan speed is changed using programs/Admin conso
[Z-Wave] - #125: RCS Z-Wave thermostat show null after failed communications ({C}viewtopic.php?f=98&t=12894&p=100710#p100710{C})
[Z-Wave] - Detect secondary issue
[Z-Wave] - Fixed detection of secondary vs primary controller
[Z-Wave] - Retry up to 3 times when connecting to Z-Wave dongle
Enhancements
[iNSTEON] - LED Bulb 12Watt PAR38 2674-222
[OPENADR] - All services are now 2b compliant
[Z-Wave] - Indicate which antenna is currently being used in GUI
[Z-Wave] - Use high power by default when including devices
[uDAjax] - More support for Z-Wave devices
Developers
Developers Links
-- URL for Web Services: {C}http://www.universal-devices.com/developers/wsdk/4.1.2{C}
-- WSDL Documentation
-- WSDK 4.1.2
***UDAjax is now included in WSDK
Bug Fixes and Enhancements in 4.1.0
Release Date
- 2013.11.06
Known Issues
- MobiLinc Connect might not work for some installations
Important Notes
Bug Fixes
[iNSTEON] - 2487S:Backlight levels not shown properly in program
[iNSTEON] - Setpoints shown as raw values in the log
[Admin Console] - Better handling of initial subscription failures
[uDAJAX] - Strange characters for the degree on thermostats including ELK thermostats
[PROGRAMS] - Fixed channel designations for Brultech not saving properly
[MOBILINC] - Changed the Dispatcher URL for MobiLinc Connect
[uI] - Fixed IP Location API to point to V3
[uI] - UI hangs when a dialog is open and other changes are made to the tree (such as name change)
Enhancements
[OPENADR20B] - Registration and reporting support
[uDI AJAX] - Added support for Foscam FI98xx (H.264) camera's (make sure you are running the updated firmware).
[bRULTECH] - Added more range for utilization in Programs
[TLS] - Support for SHA2WithRSAEncryption certificate signatures
[HTTP] - Addition of a few mime types ( viewtopic.php?f=51&t=11955)
[DASHBOARD/ZS] - Added Total Usage
[iNSTEON] - Support for Ballast Dimmer
[iNSTEON] - Support for Door Sensor
[iNSTEON] - Support for On/Off Module
Developers
- OpenADR 2.0b Registration and Report Services support
Developers Links
-- URL for Web Services: http://www.universal-devices.com/developers/wsdk/4.1.0
-- WSDK 4.1.0
      37.4k
      374.5k
