LampLinc - INSTEON Plug-In Lamp Dimmer Module (Dual-Band)
How do you get this to beep? Smarthome says it software configable, does the ISY 994 support this?
I am able to make some of my modules beep with the ISY-994. I don't have any dual-band lamplincs, but I cannot imagine why they would not be so capable.
A working example of a Program the uses the Beep capability of a Dual Band LampLinc
       Control 'MotionSensor2-Sensor' is switched On
       Repeat 5 times
          Set 'LampLinc DB' 100 (Beep Duration)
Note that none of the existing devices support the duration aspects of the Beep command. Some day SmartLabs may release a device that honors "duration" but for now the duration of the Beep is fixed by the device itself.
Thanks, tried your program, but no beep. It needs to be enabled some way. I do not know how to do that.
It should not have to be enabled. The ISY does not have a UI (Admin Console) option to Enable/Disable the Beep function on a LampLinc. My Dual Band LampLinc that beeps has firmware v.3B. What level firmware is in the LampLinc?
My lamplinc is (B2457D2) Lamplinc BiPhy v.41
