Seb50 Posted November 16, 2013 Posted November 16, 2013 Hi everybody, I'm trying to set up a rule to turn on my backyard lights when the patio door opens to let the dog out. I'm able to have the lights turn on when the patio door open to let the dog out but I would also want then to close when I let the dog back in. If I tell the ISY to have the light open for 10 minutes after the door opens when I let the dog back in and open the door again it will start a new countdown. Is it possible to have something in the rule that would not start a new countdown for when I open the door the second time to let the dog in? This is what I have for now If Time is sunset +1hour Or Time is Sunrise - 1minutes And Elk Zone Patio Physical Status is Open Then Set Balcony light On Set pool house On Else Wait 12 minutes Set Balcony lights Off Set pool house lights Off
oberkc Posted November 16, 2013 Posted November 16, 2013 I think I will stand by my suggestion on cocoontech. Did you try it?
Seb50 Posted November 16, 2013 Author Posted November 16, 2013 I think I will stand by my suggestion on cocoontech. Did you try it? what do you mean by: then Run second program (then path)
oberkc Posted November 16, 2013 Posted November 16, 2013 When one chooses a program under "action", there are choices that include "run (if)", "run then", and "run else". These refer to which of the three sections of a program (if, then, or else) to run. Once selected, it shows up in the program content as Run Program "XXXX" (then path)
apostolakisl Posted November 16, 2013 Posted November 16, 2013 This is what I have done. The first program triggers when you open the door and the light is already off. If the light is already on, then nothing happens. This calls the second program "else" path. After 10 minutes it beeps to warn you that the light is going to shut off. If you want it to stay on, you have to hit the "on" paddle and that will re-trigger the second program to run "true" which will abort the timer that shuts off the light. If Program 'Dark Outside' is True And Elk Zone 'Front Door' is Violated And Status 'Foyer / Foyer-Portico Can L' is Off Then Run Program 'front door 2' (Else Path) Else - No Actions - (To add one, press 'Action') If Control 'Foyer / Foyer-Portico Can L' is switched On Then - No Actions - (To add one, press 'Action') Else Set 'Foyer / Foyer-Portico Can L' 100% Wait 10 minutes Set 'Foyer / Foyer-Portico Can L' 250 (Beep Duration) Wait 30 seconds Set 'Foyer / Foyer-Portico Can L' Off
Seb50 Posted November 19, 2013 Author Posted November 19, 2013 This is what I have done. The first program triggers when you open the door and the light is already off. If the light is already on, then nothing happens. This calls the second program "else" path. After 10 minutes it beeps to warn you that the light is going to shut off. If you want it to stay on, you have to hit the "on" paddle and that will re-trigger the second program to run "true" which will abort the timer that shuts off the light. If Program 'Dark Outside' is True And Elk Zone 'Front Door' is Violated And Status 'Foyer / Foyer-Portico Can L' is Off [color=#FF0040]***This is where I would indicate if patio lights are off, right?*****[/color] Then Run Program 'front door 2' (Else Path) [color=#FF8040]*** would I indicate open patio light and pool house lights here?***[/color] Else - No Actions - (To add one, press 'Action') If Control 'Foyer / Foyer-Portico Can L' is switched On Then - No Actions - (To add one, press 'Action') Else Set 'Foyer / Foyer-Portico Can L' 100% Wait 10 minutes Set 'Foyer / Foyer-Portico Can L' 250 (Beep Duration) Wait 30 seconds Set 'Foyer / Foyer-Portico Can L' Off Having a trouble setting this up. Made some comments directly on the above example. Thanks in advance for your help
Seb50 Posted November 19, 2013 Author Posted November 19, 2013 This is the rule I programmed If: Program "Dark Outside" is true and ELK Zone "Patio" "physical Status is open and status "pool house" is off and Status "shed spots" is off Then: Set "pool house" on set "patio"on Else: wait minutes set "pool house" off set "balcony"off
oberkc Posted November 19, 2013 Posted November 19, 2013 I am not sure that it does all that you asked for (does it start a new countdown when you close the door, or when you open it a second time?), but if you are happy with it, then that is good enough for me.
apostolakisl Posted November 19, 2013 Posted November 19, 2013 I doubt your program is doing what you think it is. Every time you turn your pool house lights or shed spots on, that program will run and it will be false and the lights will shut off after the wait, even though the door was never opened or if "dark outside" is false. Also, at dusk, the dark outside program will change state and trigger the program to run false and the lights (if they were on) would shut off after the wait. The goal of my program was to check the status of the light when the door was opened. If the light is already on, then the assumption is that it is on for a reason and we don't want it to shut off after the wait. If the light is off to start with, opening the door will turn it on and start the timer. You need two programs to do that. You really need to do this with 2 programs. The reason is that you are going to have lots of un-intended runs of the "else" clause.
Seb50 Posted November 20, 2013 Author Posted November 20, 2013 I doubt your program is doing what you think it is. Every time you turn your pool house lights or shed spots on, that program will run and it will be false and the lights will shut off after the wait, even though the door was never opened or if "dark outside" is false. Also, at dusk, the dark outside program will change state and trigger the program to run false and the lights (if they were on) would shut off after the wait. The goal of my program was to check the status of the light when the door was opened. If the light is already on, then the assumption is that it is on for a reason and we don't want it to shut off after the wait. If the light is off to start with, opening the door will turn it on and start the timer. You need two programs to do that. You really need to do this with 2 programs. The reason is that you are going to have lots of un-intended runs of the "else" clause. Thank you for the feedback and help. I'm having issues write the rule with 2 rules as per your example. Does the below sound right? If : Program «Dark outside » is true (program outside is: If between midnight and 6am) And ELK zone “patio door†is open And balcony light is off And pool house light are off Then Run program “pitbull in the yard†(Else path) (pitbull in the yard is, Else: open balcony and pool house lights) 2nd rule This is where I’m confused. Does anything look at our place so far?
apostolakisl Posted November 20, 2013 Posted November 20, 2013 That looks fine. It will run the Else path on your second program if the door is opened while the lights are off. In your second program just have the else path turn on the light you want, wait the number of minutes you want, and turn the light off. In the "if" section put any conditions that you would like to have abort the wait. Like If If balcony light is switched on Then - - -blank Else Set balcony light on set pool house light on wait 10 minutes set balcony light off set pool house light off In this case, if someone pushes the "on" paddle of balcony light during the 10 minute wait, it will abort the wait and run the "then" clause. .. which is blank so it just does nothing.
Seb50 Posted November 26, 2013 Author Posted November 26, 2013 cool perfect it works. Thanks everybody for your input. I do have another question about writing rules. I have the below program, anything wrong with it? If Program Dark Outside is true Then Run program Christmas Tree (if) Else Set Christmas tree off
Seb50 Posted November 28, 2013 Author Posted November 28, 2013 thanks everybody for your patience and help. Enjoying the learning. I wish I could find something I can read that would accelerate my learning and I wont really need to bug you all
oberkc Posted November 28, 2013 Posted November 28, 2013 Have you read the wiki? Have you read the user manual? Have you read the manuals that come with each device?
