Configuration/Email/Customization
Just installed Insteon Smoke Bridge. I have a custom message as follows:
${sys.node.aa bb cc.name}
This should send whichever of the 7 node names that is 'on' in the message
Node examples from main page
aa.bb.cc-Smoke
aa.bb.cc-CO
aa.bb.cc-Test and so on
What I get is:
node[aa bb cc]
and 'aa b' is blue and underlined the rest of the text is black
Any ideas how to fix?
Just a wild guess, but have you tried replacing the spaces with %20
UPDATE: I tried using %20 and it did not work.
Normally the node has an additional digit. From the UDI Wiki ...
${sys.node.11 22 AA 1.name}
LeeG I saw that in the Wiki, but the ISY only shows format aa.bb.cc in the Main tab.
Well some progress.
The ISY links table does show a 1 (aa.bb.cc.1), so I put it in the customization. Now the message shows the node number and the word Smoke (when I press Test).
I was hoping that the appropriate of the 7 names would show up
Test for Test
CO for CO and so on
All nodes have a number associated with them, aa bb cc x, in the ISY. Devices such as SwitchLincs, LampLincs, ApplianceLincs always have a number 1 as there is only one node per device.
An 8 button KeypadLinc has 8 nodes numbered 1-8.
Button A is 1
Button B is 2
Button C is 3
etc
The full node identifier aa bb cc x is needed in the email messages.
The 1 is for the Primary/First node. If you want to see the value of another node for the same Insteon device use its node number.
You can see what each node has been assigned by entering ....
http://192.168.2.3/rest/nodes/
into a browser. The username/password will be solicited.
12 B9 D 1
KPL Floor Dimmer 6
1.27.54.63
true
0
0
0
12 B9 D 1
E13
12 B9 D 3
KPL Floor Dimmer 6 - A
12 B9 D 1
1.27.54.63
true
0
0
0
12 B9 D 1
F01
12 B9 D 4
KPL Floor Dimmer 6 - B
12 B9 D 1
1.27.54.63
true
0
0
0
12 B9 D 1
F02
12 B9 D 5
KPL Floor Dimmer 6 - C
12 B9 D 1
1.27.54.63
true
0
0
0
12 B9 D 1
F03
LeeG, Figured it out. Did what you said and found out each of the 7 has it's own number. So when I put that number in the message, that is the one sent.
I wanted the message to send the notification for the node that tripped. What I had to do was change the message from:
${sys.node aa bb cc 1.name} to
${sys.node.#.name}
The # pulls in the tripped node and sends it in the message.
