isy-99i pro and brultech green eye with ethernet adapter
topherhansen
I have a green eye energy meter with ethernet.
I have a isy-99i pro (no zigbee).
I want to use the energy module but it sure looks like it doesn't support anything but zigbee.
When will green eye with ethernet be supported for the energy module?
UDI will need to confirm. But, in one thread it was stated it is supported but in a very limited fashion. I believe the 32 nodes would not be present in the device tree. But, you would see a Weather Bug view of sorts if you only had the a Ethernet connection. You also need to upgrade to the 994 series as I am told.
Michel will need to confirm the above as its been a long time since I read that reply.
Teken . . .
Hello Michel,
Would you kindly state what needs to be done and what capabilities the end user would see and have going this route.
This would help out others in the future who seek the same thing on a more modest budget.
Plus, your reply could be referenced to others in the future.
Teken
Encrypted By: Phoenix Security Solutions
Oh, turns out I actually have a isy-994i IR/Pro. Leaving off digits seems like a bad thing when posting to forums.
I don't mind figuring out how to make the GEM act like a ECM (or 4 of them).
Is it possible that the Energy Module will be able to interact with what it thinks are 4 ECM's so I can get all 32 channels?
What about getting other data like the 1-wire temperature sensor data from the GEM?
Thanks for the help Teken and Michel.
The ISY currently does not capture or displays any of the 1 Wire Temperature sensors, pulse, or the current / amps. I am hoping this information will be made available in the near future.
This is currently a collaboration of efforts from UDI / Brultech.
Teken . . .
      37.6k
      376k
