2476D On Disabled, but Fast-on works
Hi,
I have two 2476Ds controlling a light on a 3 way circuit. I have them both as controllers in a group. One of them works as expected, but the other when pressed On, goes to maybe 10%. If i double tap it for fast on, it goes to 100% and nothing in between. Any thoughts? I have tried removing the faulty switch from the scene and re-adding it, but no luck.
Steve
Sounds like the local on level has be set at the switch. From the manual:
Local On-Level
Default = 100% (fixed brightness)
The local on-level is the brightness that SwitchLinc’s connected load will come on when turned on at SwitchLinc paddle Local on-level can be set to any one of 32 fixed brightness levels (3% to 100%) or “resume bright†(brightness prior to last being turned off)
To set local on level to a fixed brightness level
1) Adjust SwitchLinc to desired brightness when controlled locally
2) Tap Set button
SwitchLinc will beep
3) Test by turning SwitchLinc off and then back on (via the paddle)
SwitchLinc will turn on to new local on-level
To set local on level to the brightness level prior to being turned off
1) Turn SwitchLinc off
2) Tap Set button
3) Test:
a. Brighten SwitchLinc to a random brightness level (e.g. 75%)
b. Turn SwitchLinc off
c. Turn SwitchLinc back on
Light will turn on at the defined brightness level
-Xathros
  • 3 weeks later...
Hey guys,
Thanks for both the replies. Apologies for the late reply. The factory restore from Isy was easy and it fixed it!
Steve
