Trigger on IOLinc (TriggerLinc)
I've linked a Open/Close Sensor (Triggerlinc) to my ISY and it created 2 "devices"
(it shows up as a "2421 Triggerlinc v.34" while the actual device is a "2843-222")
Door -Closed
Door -Opened
When I open the door, i briefly see the state of "Door -Opened" going from Off to On (before it switches back to Off)
I'm trying to trigger a program based on this, but have been unable to do this..
Tried
"Control 'Door -Opened' is switched on"
"Control 'Door -Opened' is switched Fast on"
"Status 'Door -Opened' is switched on"
but nothing seem to trigger my program...
I do see events for this device:
DON 1
ST 255
DOF 1
ST 0
I assume I do something wrong and I searched the forums but have been unable to find anything about on how to get this to work... I did try to link the device with the dip switch taken off, but same results..
Post the Program. Right click on Program name, select Copy to Clipboard, paste to forum post.
An If Control 'door Opened' is switched On should work.
Make sure the Program is Enabled and not in a Folder that is False.
I got it to work, I had an AND condition in the trigger. Thanks for your help!
