LED FLOOD LIGHT
I put a LED flood light in a switch link. The LED was dimmable. It did not work and caused the switch to stop working all together. Has anyone has this problem and has anyone had any luck with an Outdoor LED Flood or spot lamp :cry:
All my outdoor flood lights are LED. I have noticed no problems, though I make no attempt to dim them.
I have several of the HomeDepot EcoSmart (LSG) 125 watt equivalent LED lights. I have them on a Switchlinc or two, and also on a Togglelinc. They are dimmable and they dim very well. No problems as of yet.
I have several Philips LED flood lights and they dim without any problem.
One thing not brought up yet.
Is the SwitchLinc you are trying to use. The 2474D two wire one that steals power through the load?
It is not made for anything but incandescent loads and may have unexpected results with other type loads.
Good one...Didn't think of that possibility.
