Folder Containing Programs
I have a folder that contains several programs on my ISY94i. The folder is assigned to a button on a KPL and runs fine when the button is activated. However, I can find no way to activate the button using MobiLinc Pro. Suggestions?
Assuming a Secondary KeypadLinc button the only way to turn On/Off that Secondary KeypadLinc button is assign the button as a Responder in an ISY Scene and turn the Scene On/Off. Secondary KeypadLinc buttons cannot be turned On/Off with Direct Insteon commands. The Direct command structure has no means of identifying which Secondary KeypadLinc button.
