Unable to add SynchroLink [Broke Again]
19.90.2C
I am attempting to add a SynchroLink to my system. The device is detected by ISY but gives an Error saying it cannot communicate with it.
I have tried moving the device into different locations, including on the same circuit as the PLM. I also have bridges installed on both lines.
Any suggestions on where to go from here?
Removed Code for Readability
So got some reading in on the forums and this I1 vs I2 post came up.
I reattempted linking with the I1 Option Selected and Nothing, with the Device Message option and nothing.
I then did a manual add with I1 Option, detected it with error message.
I then did a manual add with Device Message option and it added it completely, but came up with a communication error.
I then did a Query on it and the device Icon changed to the blue switch. I just wrote new watt values and it took.
After moving it back to the Washer room it broke again, moving back to the computer room it is still not linking. An outdoor module links in the washer room without issue so I am assuming it is not network related.
Nevermind, completely broke again. Moved it to the washer location and could not get it to communicate. Moved it back in room and going through same process I can not get it to show up on ISY at all.
I plugged in an outdoor module to the location in the washer room and linked it without an issue; so I am assuming it does not have to do with the robustness of my network.
any suggestions?
"I plugged in an outdoor module to the location in the washer room and linked it without an issue; so I am assuming it does not have to do with the robustness of my network."
Adding a Dual Band device at the plug point and have it work indicates a powerline problem.
Take a look at the initial post Hops Left=x counts. Hops Left=0 with a Max Hops=3 indicates the poorest communication. Eventually the device did not respond to a command (with retries) and the process was stopped.
I spent the day moving around the two APs and still nothing. In the same room as the PLM it barely connects.
I also have the EZ Flora that I believe is just powerline communication. I plugged it into the same spot (in both the PLM Room and Laundry Room) and it registered quickly without issue.
In the below log:
28.AA.98 is the EZ Flora (In Laundry Room)
19.90.2C is the SynchroLink (In PLM Room)
25.17.52 - is a wireless TStat that I think just happend to update during the logging session.
I added them both at the same time
Removed code for readability
My next test was to move one of the APs to the same room / circuit as the SychroLink. I got both APs on opposite circuits as verified by the 4 tap test and linked them.
For the SychroLink I tried getting it into linking mode both before the first double beep, after, and after doing the off / on calibration.
Any other suggestions?
From the event trace nothing has changed regarding the SynchroLink. The commands that work have a Hops Left=0. There are a number of cases where no command response is received for some of the initial attempts where the retries were successful. Eventually even with retries the device does not respond.
The EZFlora looks like it was on the opposite phase during the add. The commands have a consistent Hops Left=1 which often means the extra Hop is to cross over to the 120v leg containing the PLM. An EZFlora can be Dual Band. If no passthru outlet it could be Dual Band.
I would expect the SynchroLinc to work when plugged into the same outlet as the PLM. If it does not work there either there is a powerline issue as the SynchroLinc is powerline only or the SynchroLinc is not working well.
I checked the event trace for 28.AA.98. It is an I2CS device which is built on a 2413 PLM Shell. That should be a Dual Band device.
02 50 28.AA.98 22.FF.06 27 0D 02 = 0x02 is I2CS which has to be built on a 2413 PLM Shell
Thank you for looking into that depth. I'm waiting until early next week for the next test. Due to plug orientation I can't plug 2 insteon devices into the same wall plate; so I have some 1 ft extenders coming.
Is my understanding correct in that plugging the Access Point and the SynchroLink into the same wall plate should produce improved powerline communication?
I'll also be using these cables to plug the PLM and the SynchroLink into the same wall plate for a similar test.
If the Access Point is in range of another Dual Band device that is receiving the signal it should help.
Also look at what is powered on the PLM circuit. UPS, other electronic equipment, surge/noise reducing power strips should all be isolated with a FilterLinc to prevent PLM powerline traffic from being affected.
I'll do some isolation testing on this. The PLM is located in our computer room.
We have 2 power strips; one for each computer. Each powerstrip is already plugged into a FilterLinc.
So still somewhat at a loss here.
I picked up a second SynchroLink for another room. Tried linking them both in the other room and they work with a bunch of 1 and 0 hops left.
I then added several devices to different places that I was not really needing, but I wanted to increase the robustness of the mesh network.
After adding 1 more SychroLink, an EZFlora, 2 On/Off Outdoor Modules and an indoor On/Off module; I now get a bunch of 1 and 2 hops left in the new room.
The washer room still refuses to be added.
I've moved my AP/Repeaters around. I have 1 in the same outlet as the SychroLink in the washer room. The other is on the opposite circuit in an adjacent room. Still nothing.
I may be confused on these AP/Repeaters. My understanding is that they are dual band and should convert between the two. Why, even in the same plug, does the powerline not work when it is surrounded by dual band devices?
Put the PLM into test mode with 4 taps on the Set button (assuming it is a 2413). Now look at the LEDs on the Access Points. Are the Access Point LEDs blinking and what color is being displayed by the Access Point LEDs.
The AP in the middle of the house blinks Red.
The AP in the laundry room (front of house) blinks Green.
The PLM is in the back of the house.
The SynchroLinc and Access Point that is blinking Green are plugged into the same outlet?
Correct. This puts them on opposite legs right?
Yes, blinking Green indicates the PLM and Access Point are on opposite 120v legs.
Which trace was taken with the SynchroLinc and Access Point plugged into the same outlet?
19.8B.D3
Below is 2 traces. The PLM does not detect the device if anything is plugged into it. The first is where I attempted to link with something plugged into it. The second is the trace where it connected with nothing connected to it.
In this configuration, an AP is connected into the same outlet as the device.
Fri 04/18/2014 07:19:36 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/18/2014 07:19:37 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/18/2014 07:19:37 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 04/18/2014 07:19:37 PM : [  25 17 5C 1]   CLIHUM  47
Fri 04/18/2014 07:19:37 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 04/18/2014 07:19:37 PM : [  25 17 5C 1]   CLIHUM  45
Fri 04/18/2014 07:19:38 PM : [  25 17 5C 1]   CLIHUM  47
Fri 04/18/2014 07:19:38 PM : [  25 17 5C 1]   CLIHUM  48
Fri 04/18/2014 07:19:38 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 0D 00
Fri 04/18/2014 07:19:38 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 0D 00 06                 (00)
Fri 04/18/2014 07:19:47 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 0D 00
Fri 04/18/2014 07:19:47 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 0D 00 06                 (00)
Fri 04/18/2014 07:19:56 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 0D 00
Fri 04/18/2014 07:19:56 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 0D 00 06                 (00)
Fri 04/18/2014 07:20:00 PM : [19 8B D3 0  ] Failed to add device, reason 3
Fri 04/18/2014 07:20:00 PM : [        Time] 19:20:02 0(0)
Fri 04/18/2014 07:20:00 PM : [All         ] Writing 0 bytes to devices
Fri 04/18/2014 07:20:17 PM : Start Insteon Device Linking Mode
Fri 04/18/2014 07:20:17 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 04/18/2014 07:20:22 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2F           (2F)
Fri 04/18/2014 07:20:22 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:20:27 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2D           (2D)
Fri 04/18/2014 07:20:27 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:20:33 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2E           (2E)
Fri 04/18/2014 07:20:33 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:20:36 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/18/2014 07:20:36 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/18/2014 07:20:39 PM : [LNK-STAT    ] 02 53 M(01) gid=00 19.8B.D3 0709 30
Fri 04/18/2014 07:20:39 PM : [19.8B.D3 00] Linked device type=07.09 fw=30
Fri 04/18/2014 07:20:39 PM : [19 8B D3 0  ] Added to list of devices to link to ISY
Fri 04/18/2014 07:20:39 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 04/18/2014 07:20:43 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2F           (2F)
Fri 04/18/2014 07:20:43 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:20:53 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2E           (2E)
Fri 04/18/2014 07:20:53 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:20:59 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 04/18/2014 07:20:59 PM : [  25 17 5C 1]   CLIHUM  47
Fri 04/18/2014 07:20:59 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 04/18/2014 07:20:59 PM : [  25 17 5C 1]   CLIHUM  45
Fri 04/18/2014 07:20:59 PM : [  25 17 5C 1]   CLIHUM  46
Fri 04/18/2014 07:20:59 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 0D 00
Fri 04/18/2014 07:20:59 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 0D 00 06                 (00)
Fri 04/18/2014 07:21:00 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 23 0D 01           (01)
Fri 04/18/2014 07:21:00 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/18/2014 07:21:00 PM : [19 8B D3 0  ] Calibrating engine version
Fri 04/18/2014 07:21:00 PM : [19 8B D3 0  ] May not fully support i2, reverting to i1
Fri 04/18/2014 07:21:00 PM : [iNST-DUP    ] Previous message ignored.
Fri 04/18/2014 07:21:00 PM : [19 8B D3 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 04/18/2014 07:21:00 PM : [19 8B D3 1  ] Start : Adding device to ISY
Fri 04/18/2014 07:21:00 PM : [19 8B D3 1  ] Finish : Adding device to ISY was Successful
Fri 04/18/2014 07:21:00 PM : [19 8B D3 1  ] Link    0 : 0FF8 [E20122FF06010001] Saving  [E20122FF06010001]
Fri 04/18/2014 07:21:00 PM : [iNST-SRX    ] 02 50 22.0C.D4 22.FF.06 01 6E 9E           (9E)
Fri 04/18/2014 07:21:00 PM : [std-Direct  ] 22.0C.D4-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:00 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 19 00
Fri 04/18/2014 07:21:00 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/18/2014 07:21:01 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 04 00           (00)
Fri 04/18/2014 07:21:01 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:01 PM : [19 8B D3 0  ] Successfully added device
Fri 04/18/2014 07:21:01 PM : [        Time] 19:21:03 0(0)
Fri 04/18/2014 07:21:01 PM : [   22 C D4 1]       ST 158
Fri 04/18/2014 07:21:01 PM : [  19 8B D3 1]       ST   0
Fri 04/18/2014 07:21:01 PM : [All         ] Writing 8 bytes to devices
Fri 04/18/2014 07:21:01 PM : [19 8B D3 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Fri 04/18/2014 07:21:01 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 28 0F
Fri 04/18/2014 07:21:01 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 28 0F 06          SET-MSB(0F)
Fri 04/18/2014 07:21:01 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2F           (2F)
Fri 04/18/2014 07:21:01 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:01 PM : [  25 17 5C 1]   CLIHUM  47
Fri 04/18/2014 07:21:01 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 06 6F 2F           (2F)
Fri 04/18/2014 07:21:01 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=2, Hops Left=1
Fri 04/18/2014 07:21:03 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:03 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:04 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 2B F8
Fri 04/18/2014 07:21:04 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 2B F8 06          PEEK   (F8)
Fri 04/18/2014 07:21:04 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:04 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/18/2014 07:21:06 PM : [iNST-ERX    ] 02 51 19 8B D3 22 FF 06 17 88 00 00 00 E1 77 00 00 00 00 00 00 00 00 00 00
Fri 04/18/2014 07:21:06 PM : [Ext-Direct  ] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:07 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2E           (2E)
Fri 04/18/2014 07:21:07 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:07 PM : [  25 17 5C 1]   CLIHUM  46
Fri 04/18/2014 07:21:07 PM : [        Time] 19:21:09 0(0)
Fri 04/18/2014 07:21:12 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2D           (2D)
Fri 04/18/2014 07:21:12 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:12 PM : [  25 17 5C 1]   CLIHUM  45
Fri 04/18/2014 07:21:12 PM : [        Time] 19:21:14 0(0)
Fri 04/18/2014 07:21:16 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 28 0F
Fri 04/18/2014 07:21:16 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 28 0F 06          SET-MSB(0F)
Fri 04/18/2014 07:21:17 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:17 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:17 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 2B F8
Fri 04/18/2014 07:21:17 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 2B F8 06          PEEK   (F8)
Fri 04/18/2014 07:21:17 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 2B E2    PEEK   (E2)
Fri 04/18/2014 07:21:17 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 28 0F
Fri 04/18/2014 07:21:17 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 28 0F 06          SET-MSB(0F)
Fri 04/18/2014 07:21:19 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 06 6F 2E           (2E)
Fri 04/18/2014 07:21:19 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=2, Hops Left=1
Fri 04/18/2014 07:21:19 PM : [  25 17 5C 1]   CLIHUM  46
Fri 04/18/2014 07:21:19 PM : [        Time] 19:21:22 0(0)
Fri 04/18/2014 07:21:20 PM : [iNST-ERX    ] 02 51 19 8B D3 22 FF 06 17 88 00 00 00 E4 A7 00 00 00 00 00 00 00 00 00 00
Fri 04/18/2014 07:21:20 PM : [Ext-Direct  ] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:24 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 2F           (2F)
Fri 04/18/2014 07:21:24 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:24 PM : [  25 17 5C 1]   CLIHUM  47
Fri 04/18/2014 07:21:24 PM : [        Time] 19:21:26 0(0)
Fri 04/18/2014 07:21:32 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 28 0F
Fri 04/18/2014 07:21:32 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 28 0F 06          SET-MSB(0F)
Fri 04/18/2014 07:21:33 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:33 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:33 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 2B F9
Fri 04/18/2014 07:21:33 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 2B F9 06          PEEK   (F9)
Fri 04/18/2014 07:21:33 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 2B 00    PEEK   (00)
Fri 04/18/2014 07:21:33 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 29 01
Fri 04/18/2014 07:21:33 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 29 01 06          POKE   (01)
Fri 04/18/2014 07:21:35 PM : [iNST-ERX    ] 02 51 19 8B D3 22 FF 06 13 88 00 00 00 E8 7D 00 00 00 00 00 00 00 00 00 00
Fri 04/18/2014 07:21:35 PM : [Ext-Direct  ] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/18/2014 07:21:36 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/18/2014 07:21:36 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/18/2014 07:21:37 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 30           (30)
Fri 04/18/2014 07:21:37 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/18/2014 07:21:37 PM : [  25 17 5C 1]   CLIHUM  48
Fri 04/18/2014 07:21:37 PM : [        Time] 19:21:39 0(0)
Fri 04/18/2014 07:21:46 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 28 0F
Fri 04/18/2014 07:21:46 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 28 0F 06          SET-MSB(0F)
Fri 04/18/2014 07:21:47 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:47 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Fri 04/18/2014 07:21:47 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 2B F9
Fri 04/18/2014 07:21:47 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/18/2014 07:21:47 PM : [std-Direct Ack] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/18/2014 07:21:47 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 2B F9 06          PEEK   (F9)
Fri 04/18/2014 07:21:47 PM : [iNST-SRX    ] 02 50 19.8B.D3 22.FF.06 27 2B 00    PEEK   (00)
Fri 04/18/2014 07:21:47 PM : [iNST-TX-I1  ] 02 62 19 8B D3 0F 29 01
Fri 04/18/2014 07:21:47 PM : [iNST-ACK    ] 02 62 19.8B.D3 0F 29 01 06          POKE   (01)
Fri 04/18/2014 07:21:50 PM : [iNST-ERX    ] 02 51 19 8B D3 22 FF 06 13 88 00 00 00 EB B3 00 00 00 00 00 00 00 00 00 00
Fri 04/18/2014 07:21:50 PM : [Ext-Direct  ] 19.8B.D3-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/18/2014 07:21:54 PM : [19 8B D3 1  ] Link    0 : 0FF8 [E20122FF06010001] *Failed Writing [E20122FF06010001]
Fri 04/18/2014 07:21:54 PM : [  19 8B D3 1]      ERR   1
Fri 04/18/2014 07:21:54 PM : [All         ] Writing 0 bytes to devices
Fri 04/18/2014 07:21:59 PM : [        Time] 19:22:01 0(0)
So I'm at a loss now. I think there may be an issue with the PLM or some serious back feed on my powerlines.
I installed 2 toggle lincs in our master bedroom.
ISY could not detect them.
I then connected a fanlinc in the master bedroom. ISY picked up the fanlinc but still not the toggle lincs (and they are connected to the same wire...)
I then cheated a bit. I deleted the fan linc. Then connected the toggle lincs to the fan just using device to device communication.
Then I added the fan linc to the ISY and had the bottom option (keep and add existing lincs). ISY was then able to add the toggle lincs.
In my halway, I could not get another toggle linc to connect. I took a plug in on/off module; linked it to the toggle linc; then added the on/off to isy with the bottom option selected.
ISY added it without issue, and even with the on/off module unplugged the ISY can still communicate with the toggle linc.
Any suggestions for troubleshooting? I opened the breakers going to some of my unfiltered loads. All my computers are on filterlincs. Is it the PLM?
The SynchroLinc sent an Extended message in response to a Poke command. This is not valid and the ISY stopped the process. I went back to earlier posts to see if there is any correlation with other traces but found them deleted.
The Access Point has improved comm to the SynchroLinc. The earlier test where the PLM was put into the 4 tap Set button test showed the SynchroLinc is on the opposite 120v leg. The Access Point has removed one of the extra hops.
Below are two of the prior traces that I also found poke in.
19.90.2C
Fri 04/11/2014 12:54:37 PM : [19 90 2C    ] Added to list of devices to link to ISY
Fri 04/11/2014 12:54:37 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Fri 04/11/2014 12:54:37 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Fri 04/11/2014 12:54:38 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 0D 01           (01)
Fri 04/11/2014 12:54:38 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:54:38 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 10 00
Fri 04/11/2014 12:54:38 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 10 00 06          ID-REQ (00)
Fri 04/11/2014 12:54:38 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 10 00    ID-REQ (00)
Fri 04/11/2014 12:54:39 PM : [iNST-SRX    ] 02 50 19.90.2C 07.09.30 83 01 00           (00)
Fri 04/11/2014 12:54:39 PM : [std-Broadcast] 19.90.2C-->07.09.30, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:54:39 PM : [19 90 2C 0  ] Calibrating engine version
Fri 04/11/2014 12:54:39 PM : [19 90 2C 0  ] May not fully support i2, reverting to i1
Fri 04/11/2014 12:54:39 PM : [19 90 2C 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 04/11/2014 12:54:39 PM : [19 90 2C 1  ] Start : Adding device to ISY
Fri 04/11/2014 12:54:39 PM : [19 90 2C 1  ] Finish : Adding device to ISY was Successful
Fri 04/11/2014 12:54:39 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Saving  [E20122FF06010001]
Fri 04/11/2014 12:54:39 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:54:39 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:54:39 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 00 00           (00)
Fri 04/11/2014 12:54:39 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:54:39 PM : [  19 90 2C 1]       ST   0
Fri 04/11/2014 12:54:39 PM : [19 90 2C 0  ] Successfully added device
Fri 04/11/2014 12:54:39 PM : [All         ] Writing 8 bytes to devices
Fri 04/11/2014 12:54:40 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Fri 04/11/2014 12:54:40 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:54:40 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:54:42 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/11/2014 12:54:42 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:54:42 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Fri 04/11/2014 12:54:42 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Fri 04/11/2014 12:54:42 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2B 00    PEEK   (00)
Fri 04/11/2014 12:54:42 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 29 E2
Fri 04/11/2014 12:54:42 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 29 E2 06          POKE   (E2)
Fri 04/11/2014 12:54:51 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:54:51 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:54:52 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/11/2014 12:54:52 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:54:52 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Fri 04/11/2014 12:54:52 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Fri 04/11/2014 12:55:01 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:55:01 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:55:03 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/11/2014 12:55:03 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:55:03 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Fri 04/11/2014 12:55:03 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Fri 04/11/2014 12:55:07 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] *Failed Writing [E20122FF06010001]
Fri 04/11/2014 12:55:07 PM : [  19 90 2C 1]      ERR   1
Fri 04/11/2014 12:55:11 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/11/2014 12:55:11 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/11/2014 12:55:19 PM : [19 90 2C 1  ] Link    0 : 0FF8 [620122FF06010001] Saving  [62..............]
Fri 04/11/2014 12:55:19 PM : [19 90 2C 1  ] Start : Removing device from ISY
Fri 04/11/2014 12:55:19 PM : [19 90 2C 1  ] Finish : Removing from ISY was Successful
Fri 04/11/2014 12:55:19 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:55:30 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:55:49 PM : [19 90 2C    ] Added to list of devices to link to ISY
Fri 04/11/2014 12:55:49 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Fri 04/11/2014 12:55:49 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Fri 04/11/2014 12:55:50 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 0D 01           (01)
Fri 04/11/2014 12:55:50 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:55:50 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 10 00
Fri 04/11/2014 12:55:50 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 10 00 06          ID-REQ (00)
Fri 04/11/2014 12:55:50 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 10 00    ID-REQ (00)
Fri 04/11/2014 12:55:50 PM : [iNST-SRX    ] 02 50 19.90.2C 07.09.30 83 01 00           (00)
Fri 04/11/2014 12:55:50 PM : [std-Broadcast] 19.90.2C-->07.09.30, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:55:50 PM : [19 90 2C 0  ] Calibrating engine version
Fri 04/11/2014 12:55:50 PM : [19 90 2C 0  ] May not fully support i2, reverting to i1
Fri 04/11/2014 12:55:50 PM : [19 90 2C 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 04/11/2014 12:55:50 PM : [19 90 2C 1  ] Start : Adding device to ISY
Fri 04/11/2014 12:55:50 PM : [19 90 2C 1  ] Finish : Adding device to ISY was Successful
Fri 04/11/2014 12:55:50 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Saving  [E20122FF06010001]
Fri 04/11/2014 12:55:51 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:55:51 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:56:00 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:56:00 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:56:09 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:56:09 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:56:09 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 01 00           (00)
Fri 04/11/2014 12:56:09 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:56:09 PM : [  19 90 2C 1]       ST   0
Fri 04/11/2014 12:56:09 PM : [19 90 2C 0  ] Successfully added device
Fri 04/11/2014 12:56:09 PM : [All         ] Writing 8 bytes to devices
Fri 04/11/2014 12:56:09 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Fri 04/11/2014 12:56:09 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:56:09 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:56:10 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/11/2014 12:56:10 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:56:10 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Fri 04/11/2014 12:56:10 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Fri 04/11/2014 12:56:11 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/11/2014 12:56:11 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/11/2014 12:56:19 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:56:19 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:56:20 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Fri 04/11/2014 12:56:20 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:56:20 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Fri 04/11/2014 12:56:20 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Fri 04/11/2014 12:56:20 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2B E2    PEEK   (E2)
Fri 04/11/2014 12:56:20 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:56:20 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:56:29 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:56:29 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:56:38 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Fri 04/11/2014 12:56:38 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Fri 04/11/2014 12:56:42 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 2F 13 00 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:56:42 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:56:46 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] *Failed Writing [E20122FF06010001]
Fri 04/11/2014 12:56:46 PM : [  19 90 2C 1]      ERR   1
Fri 04/11/2014 12:56:56 PM : [19 90 2C 1  ] Link    0 : 0FF8 [620122FF06010001] Saving  [62..............]
Fri 04/11/2014 12:56:56 PM : [19 90 2C 1  ] Start : Removing device from ISY
Fri 04/11/2014 12:56:56 PM : [19 90 2C 1  ] Finish : Removing from ISY was Successful
Fri 04/11/2014 12:56:56 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:57:01 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:57:03 PM : Start Insteon Device Linking Mode
Fri 04/11/2014 12:57:03 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 04/11/2014 12:57:07 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 04/11/2014 12:57:07 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 04/11/2014 12:57:07 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:57:11 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/11/2014 12:57:11 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/11/2014 12:57:14 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D
Fri 04/11/2014 12:57:14 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D 06        (08)
Fri 04/11/2014 12:57:15 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 6B 08           (08)
Fri 04/11/2014 12:57:15 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 04/11/2014 12:57:15 PM : [  25 17 5C 1]    CLIFS   8
Fri 04/11/2014 12:57:18 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 70 03           (03)
Fri 04/11/2014 12:57:18 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/11/2014 12:57:18 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96
Fri 04/11/2014 12:57:18 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06        (02)
Fri 04/11/2014 12:57:19 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 2E 02           (02)
Fri 04/11/2014 12:57:19 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 04/11/2014 12:57:19 PM : [iNST-ERX    ] 02 51 25 17 5C 22 FF 06 11 2E 02 01 06 0A 1C 2F 10 49 28 00 EB A1 44 1D 4A
Fri 04/11/2014 12:57:19 PM : [Ext-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/11/2014 12:57:26 PM : [        Time] 12:57:27 1(0)
Fri 04/11/2014 12:57:26 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6D 8A 00 00 00 00 00 00 00 00 00 00 00 00 00 09
Fri 04/11/2014 12:57:26 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 6D 8A 00 00 00 00 00 00 00 00 00 00 00 00 00 09 06        (8A)
Fri 04/11/2014 12:57:26 PM : [19 90 2C    ] Added to list of devices to link to ISY
Fri 04/11/2014 12:57:27 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 6D 8A           (8A)
Fri 04/11/2014 12:57:27 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 04/11/2014 12:57:27 PM : [  25 17 5C 1]   CLISPH 138
Fri 04/11/2014 12:57:27 PM : [VAR  2   14 ]       69
Fri 04/11/2014 12:57:27 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Fri 04/11/2014 12:57:27 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Fri 04/11/2014 12:57:27 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 0D 01           (01)
Fri 04/11/2014 12:57:27 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:27 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 10 00
Fri 04/11/2014 12:57:28 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 10 00 06          ID-REQ (00)
Fri 04/11/2014 12:57:30 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 72 45           (45)
Fri 04/11/2014 12:57:30 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/11/2014 12:57:39 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 10 00
Fri 04/11/2014 12:57:39 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 10 00 06          ID-REQ (00)
Fri 04/11/2014 12:57:39 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 10 00    ID-REQ (00)
Fri 04/11/2014 12:57:39 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:40 PM : [iNST-SRX    ] 02 50 19.90.2C 07.09.30 83 01 00           (00)
Fri 04/11/2014 12:57:40 PM : [std-Broadcast] 19.90.2C-->07.09.30, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:40 PM : [19 90 2C 0  ] Calibrating engine version
Fri 04/11/2014 12:57:40 PM : [19 90 2C 0  ] May not fully support i2, reverting to i1
Fri 04/11/2014 12:57:40 PM : [19 90 2C 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 04/11/2014 12:57:40 PM : [19 90 2C 1  ] Start : Adding device to ISY
Fri 04/11/2014 12:57:40 PM : [19 90 2C 1  ] Finish : Adding device to ISY was Successful
Fri 04/11/2014 12:57:40 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Saving  [E20122FF06010001]
Fri 04/11/2014 12:57:40 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:57:40 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:57:42 PM : [        Time] 12:57:43 1(0)
Fri 04/11/2014 12:57:49 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:57:49 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:57:50 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 01 00           (00)
Fri 04/11/2014 12:57:50 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:50 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6C 94 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:57:50 PM : [19 90 2C 0  ] Successfully added device
Fri 04/11/2014 12:57:50 PM : [All         ] Writing 8 bytes to devices
Fri 04/11/2014 12:57:50 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Fri 04/11/2014 12:57:51 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 6C 94 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06        (94)
Fri 04/11/2014 12:57:52 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 6C 94           (94)
Fri 04/11/2014 12:57:52 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 04/11/2014 12:57:52 PM : [  19 90 2C 1]       ST   0
Fri 04/11/2014 12:57:52 PM : [  25 17 5C 1]   CLISPC 148
Fri 04/11/2014 12:57:52 PM : [VAR  2    9 ]       74
Fri 04/11/2014 12:57:52 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2F 00 00 02 0F FF 08 E2 01 22 FF 06 01 00 01 00
Fri 04/11/2014 12:57:52 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2F 00 00 02 0F FF 08 E2 01 22 FF 06 01 00 01 00 06        (00)
Fri 04/11/2014 12:57:54 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2F 00           (00)
Fri 04/11/2014 12:57:54 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:54 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 19 90 2C 07 09 30 06
Fri 04/11/2014 12:57:54 PM : [PLM         ] Group   1 : Writing Responder Link matching [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001]
Fri 04/11/2014 12:57:54 PM : [19 90 2C 1  ] Link    1 : 0FF0 [0000000000000000] Writing [00..............]
Fri 04/11/2014 12:57:54 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:57:55 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:57:57 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2F 00           (00)
Fri 04/11/2014 12:57:57 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:57 PM : [19 90 2C 1  ] Link    2 : 0FE8 : Writing High Water Byte
Fri 04/11/2014 12:57:57 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:57:57 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:57:58 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2F 00           (00)
Fri 04/11/2014 12:57:58 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:57:58 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 71 4A           (4A)
Fri 04/11/2014 12:57:58 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/11/2014 12:58:07 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:07 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:58:08 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2F 00           (00)
Fri 04/11/2014 12:58:08 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:11 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Fri 04/11/2014 12:58:11 PM : CLI-WBug: Successfully Processed WBug Response
Fri 04/11/2014 12:58:17 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:17 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:58:17 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2F 00           (00)
Fri 04/11/2014 12:58:17 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:20 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 2F 00 01 01 00 EF 01 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:20 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:20 PM : [Ext MH      ] Unexpected Response (i.e. DB range): ignored
Fri 04/11/2014 12:58:24 PM : [  19 90 2C 1]      ERR   1
Fri 04/11/2014 12:58:34 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Fri 04/11/2014 12:58:34 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Fri 04/11/2014 12:58:35 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 04 00           (00)
Fri 04/11/2014 12:58:35 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:35 PM : [  19 90 2C 1]      ERR   0
Fri 04/11/2014 12:58:35 PM : [  19 90 2C 1]       ST   0
Fri 04/11/2014 12:58:36 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 4A 3E 00 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:36 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:42 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:42 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:58:46 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2E 00           (00)
Fri 04/11/2014 12:58:46 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:49 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 2E 00 00 01 00 09 14 05 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:58:49 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:58:49 PM : [All         ] Writing 0 bytes to devices
Fri 04/11/2014 12:58:52 PM : [ZWAVE-RX ZW008_1] [0114000400080E32]...
Fri 04/11/2014 12:58:52 PM : [ZWAVE-TX        ] ACK
Fri 04/11/2014 12:58:57 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 6F 27           (27)
Fri 04/11/2014 12:58:57 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 04/11/2014 12:58:57 PM : [  25 17 5C 1]   CLIHUM  39
Fri 04/11/2014 12:58:57 PM : [        Time] 12:58:58 1(0)
Fri 04/11/2014 12:59:00 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 02 00 0F 14 05 00 00 00 00 00 00 00 00
Fri 04/11/2014 12:59:00 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 02 00 0F 14 05 00 00 00 00 00 00 00 00 06        (00)
Fri 04/11/2014 12:59:01 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2E 00           (00)
Fri 04/11/2014 12:59:01 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 04/11/2014 12:59:01 PM : [All         ] Writing 0 bytes to devices
Sat 04/12/2014 02:49:42 PM : Start Insteon Device Linking Mode
Sat 04/12/2014 02:49:42 PM : [LNK-BGN     ] 02 64 01 00 06
Sat 04/12/2014 02:50:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:50:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:50:44 PM : [iNST-SRX    ] 02 50 25.17.5C 00.00.01 CB 11 00    LTONRR (00)
Sat 04/12/2014 02:50:44 PM : [std-Group   ] 25.17.5C-->Group=1, Max Hops=3, Hops Left=2
Sat 04/12/2014 02:50:44 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 40 11 01    LTONRR (01)
Sat 04/12/2014 02:50:44 PM : [std-Cleanup ] 25.17.5C-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Sat 04/12/2014 02:50:44 PM : [iNST-DUP    ] Previous message ignored.
Sat 04/12/2014 02:50:44 PM : [iNST-SRX    ] 02 50 25.17.5C 11.00.01 CB 06 00           (00)
Sat 04/12/2014 02:50:44 PM : [std-Group   ] 25.17.5C-->11.00.01, Max Hops=3, Hops Left=2
Sat 04/12/2014 02:50:44 PM : [iNST-INFO   ] Previous message ignored.
Sat 04/12/2014 02:50:46 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 72 3E           (3E)
Sat 04/12/2014 02:50:46 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 04/12/2014 02:50:47 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 71 46           (46)
Sat 04/12/2014 02:50:47 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 04/12/2014 02:51:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:51:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:51:59 PM : [LNK-STAT    ] 02 53 M(01) gid=00 28.AA.98 0400 28
Sat 04/12/2014 02:51:59 PM : [28.AA.98 00] Linked device type=04.00 fw=28
Sat 04/12/2014 02:51:59 PM : [28 AA 98 0  ] Added to list of devices to link to ISY
Sat 04/12/2014 02:51:59 PM : [LNK-BGN     ] 02 64 01 00 06
Sat 04/12/2014 02:52:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:52:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:52:37 PM : [LNK-STAT    ] 02 53 M(01) gid=00 19.90.2C 0709 30
Sat 04/12/2014 02:52:37 PM : [19.90.2C 00] Linked device type=07.09 fw=30
Sat 04/12/2014 02:52:37 PM : [19 90 2C 0  ] Added to list of devices to link to ISY
Sat 04/12/2014 02:52:37 PM : [LNK-BGN     ] 02 64 01 00 06
Sat 04/12/2014 02:52:50 PM : Stop Insteon Device Linking Mode, Final processing to follow
Sat 04/12/2014 02:52:50 PM : [  25 17 5C 2]      DON   0
Sat 04/12/2014 02:52:50 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Sat 04/12/2014 02:52:50 PM : [  25 17 5C 2]       ST 255
Sat 04/12/2014 02:52:50 PM : [  25 17 5C 1]   CLIHCS   2
Sat 04/12/2014 02:52:50 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D
Sat 04/12/2014 02:52:52 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D 06        (08)
Sat 04/12/2014 02:52:53 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 6B 08           (08)
Sat 04/12/2014 02:52:53 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 04/12/2014 02:52:53 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D
Sat 04/12/2014 02:52:54 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 6B 08 00 00 00 00 00 00 00 00 00 00 00 00 00 8D 06        (08)
Sat 04/12/2014 02:52:55 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 6B 08           (08)
Sat 04/12/2014 02:52:55 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 04/12/2014 02:52:55 PM : [  25 17 5C 2]      DON   0
Sat 04/12/2014 02:52:55 PM : [  25 17 5C 1]   CLISPH 124
Sat 04/12/2014 02:52:55 PM : [  25 17 5C 1]   CLISPC 140
Sat 04/12/2014 02:52:55 PM : [iNST-TX-I1  ] 02 62 28 AA 98 0F 0D 00
Sat 04/12/2014 02:52:55 PM : [iNST-ACK    ] 02 62 28.AA.98 0F 0D 00 06                 (00)
Sat 04/12/2014 02:52:55 PM : [iNST-SRX    ] 02 50 28.AA.98 22.FF.06 27 0D 02           (02)
Sat 04/12/2014 02:52:55 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 04/12/2014 02:52:55 PM : [28 AA 98 0  ] Calibrating engine version
Sat 04/12/2014 02:52:55 PM : [iNST-TX-I2CS] 02 62 28 AA 98 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sat 04/12/2014 02:52:56 PM : [iNST-ACK    ] 02 62 28.AA.98 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sat 04/12/2014 02:52:56 PM : [iNST-SRX    ] 02 50 28.AA.98 22.FF.06 27 2F 00           (00)
Sat 04/12/2014 02:52:56 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 04/12/2014 02:52:56 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 01 70 03           (03)
Sat 04/12/2014 02:52:56 PM : [std-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 04/12/2014 02:52:57 PM : [iNST-ERX    ] 02 51 28 AA 98 22 FF 06 12 2F 00 00 01 1F FF 00 A2 00 22 FF 06 00 00 00 E9
Sat 04/12/2014 02:52:57 PM : [Ext-Direct  ] 28.AA.98-->ISY/PLM Group=0, Max Hops=2, Hops Left=0
Sat 04/12/2014 02:52:57 PM : [28 AA 98 0  ] Using Database Link Table offset 0x1FF8 (reported 0x1FF8)
Sat 04/12/2014 02:52:57 PM : [28 AA 98 1  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:57 PM : [28 AA 98 1  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:57 PM : [iNST-TX-I2CS] 02 62 25 17 5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96
Sat 04/12/2014 02:52:58 PM : [iNST-ACK    ] 02 62 25.17.5C 1F 2E 02 00 00 00 00 00 00 00 00 00 00 00 00 92 96 06        (02)
Sat 04/12/2014 02:52:58 PM : [iNST-SRX    ] 02 50 25.17.5C 22.FF.06 2B 2E 02           (02)
Sat 04/12/2014 02:52:58 PM : [std-Direct Ack] 25.17.5C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 04/12/2014 02:52:58 PM : [iNST-ERX    ] 02 51 25 17 5C 22 FF 06 11 2E 02 01 00 0C 18 2B 10 46 30 00 E6 A1 3E 3F 4B
Sat 04/12/2014 02:52:58 PM : [Ext-Direct  ] 25.17.5C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 04/12/2014 02:52:58 PM : [iNST-TX-I1  ] 02 62 28 AA 98 0F 44 09
Sat 04/12/2014 02:52:58 PM : [iNST-ACK    ] 02 62 28.AA.98 0F 44 09 06                 (09)
Sat 04/12/2014 02:52:59 PM : [iNST-SRX    ] 02 50 28.AA.98 22.FF.06 27 44 00           (00)
Sat 04/12/2014 02:52:59 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 04/12/2014 02:52:59 PM : [28 AA 98 2  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 2  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 3  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 3  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 4  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 4  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 5  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 5  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 6  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 6  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 7  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 7  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [28 AA 98 8  ] Start : Adding device to ISY
Sat 04/12/2014 02:52:59 PM : [28 AA 98 8  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:52:59 PM : [iNST-TX-I1  ] 02 62 28 AA 98 0F 44 02
Sat 04/12/2014 02:52:59 PM : [iNST-ACK    ] 02 62 28.AA.98 0F 44 02 06                 (02)
Sat 04/12/2014 02:53:00 PM : [iNST-SRX    ] 02 50 28.AA.98 22.FF.06 27 44 00           (00)
Sat 04/12/2014 02:53:00 PM : [std-Direct Ack] 28.AA.98-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 04/12/2014 02:53:00 PM : [28 AA 98 0  ] Successfully added device
Sat 04/12/2014 02:53:00 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Sat 04/12/2014 02:53:00 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Sat 04/12/2014 02:53:09 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Sat 04/12/2014 02:53:09 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Sat 04/12/2014 02:53:18 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 0D 00
Sat 04/12/2014 02:53:18 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 0D 00 06                 (00)
Sat 04/12/2014 02:53:18 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 0D 01           (01)
Sat 04/12/2014 02:53:18 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:18 PM : [19 90 2C 0  ] Calibrating engine version
Sat 04/12/2014 02:53:18 PM : [19 90 2C 0  ] May not fully support i2, reverting to i1
Sat 04/12/2014 02:53:18 PM : [19 90 2C 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sat 04/12/2014 02:53:18 PM : [iNST-DUP    ] Previous message ignored.
Sat 04/12/2014 02:53:18 PM : [19 90 2C 1  ] Start : Adding device to ISY
Sat 04/12/2014 02:53:18 PM : [19 90 2C 1  ] Finish : Adding device to ISY was Successful
Sat 04/12/2014 02:53:18 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Saving  [E20122FF06010001]
Sat 04/12/2014 02:53:18 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Sat 04/12/2014 02:53:18 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Sat 04/12/2014 02:53:21 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 08 17 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:53:21 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:22 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 08 17 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:53:22 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:53:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:53:31 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Sat 04/12/2014 02:53:31 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Sat 04/12/2014 02:53:40 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Sat 04/12/2014 02:53:40 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Sat 04/12/2014 02:53:41 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 01 00           (00)
Sat 04/12/2014 02:53:41 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:41 PM : [19 90 2C 0  ] Successfully added device
Sat 04/12/2014 02:53:42 PM : [VAR  2   11 ]       1
Sat 04/12/2014 02:53:42 PM : [VAR  2   12 ]       0
Sat 04/12/2014 02:53:42 PM : [  25 17 5C 1]    CLIFS   8
Sat 04/12/2014 02:53:42 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 0D 75 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:53:42 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:42 PM : [VAR  2   14 ]       62
Sat 04/12/2014 02:53:42 PM : [VAR  2    9 ]       70
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 1]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 2]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 3]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 4]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 5]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 6]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 7]       ST   0
Sat 04/12/2014 02:53:42 PM : [  28 AA 98 8]       ST   0
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1  1] 882000.000000  Weather - Temperature = 88.2 °F
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1  2] 890000.000000  Weather - Temperature High = 89 °F
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1  4] 840000.000000  Weather - Feels Like = 84 °F
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1  8] 298200.000000  Weather - Pressure = 29.82 inches
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1 13] 120000.000000  Weather - Wind Direction = WSW
Sat 04/12/2014 02:53:42 PM : [MOD  2  2  1 15] 270000.000000  Weather - Gust Speed = 27 mph
Sat 04/12/2014 02:53:42 PM : [  19 90 2C 1]       ST   0
Sat 04/12/2014 02:53:42 PM : [All         ] Writing 8 bytes to devices
Sat 04/12/2014 02:53:43 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 0D 75 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:53:43 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:53:43 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Sat 04/12/2014 02:53:43 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:53:43 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:53:52 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:53:52 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:54:01 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:54:01 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:54:05 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] *Failed Writing [E20122FF06010001]
Sat 04/12/2014 02:54:05 PM : [  19 90 2C 1]      ERR   1
Sat 04/12/2014 02:54:05 PM : [All         ] Writing 0 bytes to devices
Sat 04/12/2014 02:54:16 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Sat 04/12/2014 02:54:16 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Sat 04/12/2014 02:54:25 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 19 00
Sat 04/12/2014 02:54:25 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 19 00 06          LTSREQ (LIGHT)
Sat 04/12/2014 02:54:26 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 27 01 00           (00)
Sat 04/12/2014 02:54:26 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 04/12/2014 02:54:26 PM : [  19 90 2C 1]      ERR   0
Sat 04/12/2014 02:54:26 PM : [  19 90 2C 1]       ST   0
Sat 04/12/2014 02:54:27 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 17 F9 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:54:27 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:54:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:54:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:54:39 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:54:39 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06        (00)
Sat 04/12/2014 02:54:48 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:54:48 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06        (00)
Sat 04/12/2014 02:54:57 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:54:57 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06        (00)
Sat 04/12/2014 02:55:01 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2E 00           (00)
Sat 04/12/2014 02:55:01 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:02 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 2E 00 00 01 00 09 14 05 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:02 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:02 PM : [All         ] Writing 8 bytes to devices
Sat 04/12/2014 02:55:02 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] Writing [E20122FF06010001]
Sat 04/12/2014 02:55:02 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:55:02 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:55:11 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:55:11 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:55:13 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Sat 04/12/2014 02:55:13 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:13 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Sat 04/12/2014 02:55:13 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Sat 04/12/2014 02:55:16 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 23 07 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:16 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:17 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 23 07 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:17 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:26 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 28 0F
Sat 04/12/2014 02:55:26 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 28 0F 06          SET-MSB(0F)
Sat 04/12/2014 02:55:28 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 28 0F    SET-MSB(0F)
Sat 04/12/2014 02:55:28 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:28 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 2B F8
Sat 04/12/2014 02:55:28 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 2B F8 06          PEEK   (F8)
Sat 04/12/2014 02:55:29 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2B A2    PEEK   (A2)
Sat 04/12/2014 02:55:29 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:29 PM : [iNST-TX-I1  ] 02 62 19 90 2C 0F 29 E2
Sat 04/12/2014 02:55:29 PM : [iNST-ACK    ] 02 62 19.90.2C 0F 29 E2 06          POKE   (E2)
Sat 04/12/2014 02:55:30 PM : CLI-WBug: Connecting to datafeed.weatherbug.com
Sat 04/12/2014 02:55:30 PM : CLI-WBug: Successfully Processed WBug Response
Sat 04/12/2014 02:55:32 PM : [iNST-ERX    ] 02 51 19 90 2C 22 FF 06 13 88 00 00 00 26 BA 00 00 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:32 PM : [Ext-Direct  ] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:36 PM : [19 90 2C 1  ] Link    0 : 0FF8 [E20122FF06010001] *Failed Writing [E20122FF06010001]
Sat 04/12/2014 02:55:36 PM : [  19 90 2C 1]      ERR   1
Sat 04/12/2014 02:55:41 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 02 00 09 14 05 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:41 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 02 00 09 14 05 00 00 00 00 00 00 00 00 06        (00)
Sat 04/12/2014 02:55:50 PM : [iNST-TX-I2  ] 02 62 19 90 2C 1F 2E 00 00 02 00 09 14 05 00 00 00 00 00 00 00 00
Sat 04/12/2014 02:55:50 PM : [iNST-ACK    ] 02 62 19.90.2C 1F 2E 00 00 02 00 09 14 05 00 00 00 00 00 00 00 00 06        (00)
Sat 04/12/2014 02:55:51 PM : [iNST-SRX    ] 02 50 19.90.2C 22.FF.06 23 2E 00           (00)
Sat 04/12/2014 02:55:51 PM : [std-Direct Ack] 19.90.2C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 04/12/2014 02:55:51 PM : [All         ] Writing 0 bytes to devices
I am one confused individual. I thought the issue was not able to add a SynchroLinc. The last trace (not the two that were just posted that I assume were some that were deleted) is not the SynchroLinc (19.8B.D3).
Correct,ish. In a prior post I mentioned having a second SynchroLink. I moved that to the same location as the first to rule out a defective unit.
19.90.2C
19.8B.D3
Same location in the laundry, I unplugged the 2C and plugged in the D3 into the same outlet.
Bleh;
So next test, same as the old ones. This time changed my expectations.
The SynchroLinc does not sync at all if it has a load (even off) plugged into it.
I can get it to Sync with nothing connected to it with the AP in the same outlet.
I then click on Options and change the values (On/Time/Hyst) to what I like and write it.
I then plug in the load and have it run its cycle.
The SynchroLinc gives On/Off messages as expected (still testing a full cycle).
If I hit options, I get an error saying it can not communicate.
So, assuming it can pass a couple full washer load tests, it may be a livable condition.
I should add that a Query gives communication issues as well.
It goes to a red ! after a query. But once the status changes from off/on on/off then it goes back to the blue switch.
Can you try putting a filterlinc between the load and the Syncrolinc or is the load too heavy for that?
-Xathros
