Program execution order question
I'm not seeing why this never runs...I've tried many different ways...This is what I've been staring at recently. It doesn't run even though both climate expressions are true..?
            Time is  9:15:00AM
         Or Time is  5:15:00PM
   And (
            Module 'Climate' Temperature > 34 °F
        And Module 'Climate' Rain Today < 0.03 "
       Set 'Front Drip-Relay' On
       Wait  10 minutes
       Set 'Front Drip-Relay' Off
       Wait  3 seconds
       Send Notification to 'Patrick E-mail' content 'Front Drip Off'
Is it something to do with maybe the climate data being re-evaluated during the wait period?
I see where the last run/finish times are updated more frequently that my desired run times...
If I run the then statement it sets the relay on for about a minute then sets it off and never completes the then statement..
The Program is triggered at the two Times and anytime either of the two Climate values change. The If will be True only at exactly 9:15AM and exactly 5:15PM assuming the Climate values are also True. Perhaps you want to use a From/To Time range rather than two explicit Times. Would help to know what the program is trying to accomplish and when.
Trying to run the then statement at 9:15 am and 5:15 pm only if temp is above 34 and if there is less than .03" of rain for that day.
Wanting to run (have relay on ) for 10 min at these times then turn off.
Put the notification in only to see if complete.
If either Climate value changes while in the Wait the statements after Wait will not execute. The Wait is stopped and the If will be False because neither Time is current.
Suggestion on how to accomplish this issue would be most appreciated!
( Just got my Global Cache itach flex to work this past weekend and my brain is fried from dialing it in......)
The common solution is to split the Program into two Programs. Program 1 Then clause invokes Program 2. Program 2 contains the current Then clause statements. Even though Program 1 is triggered multiple times it would not affect the execution of Program 2.
