Programming the Status of a KPL Button?
I am trying to write a program that does the following:
If KPL button D is on, turn devices B and C on. Wait 2 minutes and turn device C off. I am able to program that successfully but after device C turns off I would like to program KPL button D to go to its off state. Is that possible? If so, how?
Place KPL Button D into a Scene as a Responder and turn that scene off to make the LED light go out.
So, when someone turns on KPL D, you want it to turn off after two minutes, along with KPL C? OK. You did not state what you want to happen if KPL turns off during the two-minute timer, so I will make no assumptions.
Status KPL D is on
then
set KPL C on
set KPL B on
wait 2 minutes
set KPL C off
set KPL D off
else
nothing
oberkc:
That is precisely what I am trying to do but I cannot find the KPL Off command. Where is it located?
Ah, yes. My fault. I always forget this problem.
Secondary buttons cannot be controlled directly, unfortunately. They have to be put into a scene. If need be, create a scene with a single device: the KPL button. The program would then be:
if
status KPLD is on
then
set scene with KPLC on
set scene with KPLB on
wait 2 minutes
set scene with KPLC off
set scene with KPLD off
else
nothing
sorry for my forgetfulness.
Will this variation of your suggestion work?
if
status KPLD is on
then
set device C on
set device B on
wait 2 minutes
set device C off
else
nothing
