Hidden Door Sensor 2845-222 WORKAROUND
BitSmith
Seems the ISY is not quite ready for the Hidden Door Sensor (HDS) yet. Here's a simple workaround:
Link the HDS (as a controller) to an unused button on a KPL (as a responder).
Then use that button as a controller to whatever you want to do with the ISY!
And I've written a few other hopefully helpful routines;
http://wiki.universal-devices.com/index ... r:BitSmith
Cheers, BitSmith
I have not had any problem linking or using this sensor. Please elaborate on the issue that are you addressing.
Thanks, tandar
My first problem is that I had the device address wrong. The labels are so darn small, that even with light I got a B and 8 confused. I verified with a magnifier...
So I tried again to add as either automatic or TriggerLinc [10.02] (2421) TriggerLinc
I get the error: Unsupported Device:16.17
How are you able to add the device?
Thanks.
Just in case the idea is lost, the cat 16, subcat 17 are decimal numbers. When looking at the New INSTEON Device list that is the same as [10.11] which are hex numbers; 0x10=16 decimal 0x11=17 decimal
Good idea, Brian H. I'm kinda slow to check beta versions - especially right before a critical need - but I did and installed v4.2.1.
So Click Link Management, Link the sensor, and there it is!
Note: Once it's connected, [Options] allows for the LED to be turned off. I don't know how much battery power it will save, but certainly something.
      37.8k
      377.8k
