Chrone can not log into Admin Console => no /web/insteon.jar
I am trying to connect to the Admin console via Chrome but get this Java Error message.... Java is installed
What do I need to do to correct? Thanks! => see details below:
Java Plug-in 10.55.2.14
Using JRE version 1.7.0_55-b14 Java HotSpot Client VM
User home directory = C:\Users\Currie
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
java.lang.NullPointerException
at sun.awt.SunToolkit.getSystemEventQueueImplPP(Unknown Source)
at sun.awt.SunToolkit.getSystemEventQueueImpl(Unknown Source)
at java.awt.Toolkit.getEventQueue(Unknown Source)
at java.awt.EventQueue.invokeLater(Unknown Source)
at sun.awt.windows.WToolkit.windowsSettingChange(Unknown Source)
at sun.awt.windows.WToolkit.eventLoop(Native Method)
at sun.awt.windows.WToolkit.run(Unknown Source)
CacheEntry[http]: updateAvailable=false,lastModified=Mon Dec 31 19:18:03 EST 1979,length=3424585
Resource http://crl.globalsign.net/root.crl has future expires: Sat May 10 16:57:35 EDT 2014 update check skipped.
Thanks I have a 994i and the latest version of the firmware... I used to be able to connect... sudden;y stopped working... I have also tried re-booting everything!
