Irrigation module not available
Greetings, I would like to use the irrigation module plug-in but it isn't on the list of available plug-ins from the help section if the admin console. Is it because I am using an apple computer? I have an isy99ir pro running ud.v3.3.10 firmware. Internet access is set to disabled but I use mobilinc connect to control from outside the network. That is the only module it shows as installed, the portal integration module. Available modules shown are network module, x10 module, and elk integration module. No irrigation module. Thanks for any help, John
Hello John,
It has been removed do to changes in its API and changes to their TOS (terms of service). UDI is currently working on an alternative solution at this time.
Teken . . .
Encrypted By: Phoenix Security Solutions
