oberkc Posted May 21, 2014 Share Posted May 21, 2014 LeeG, Early you suggested (I think) using a direct command to trigger the relay. I vaguely recall other posts where I thought I understood the IOLinc responds in momentary mode only to scene commands. Am I recalling incorrectly? Yes, I agree that the button looks like a simple momentary contact button. This should work, yes! Pintu1228, If you wall button still works, make sure that the wires connected to the IOLinc go to the same wires as the wall button. Link to comment
LeeG Posted May 21, 2014 Share Posted May 21, 2014 The I/O Linc Relay responds to Direct commands using the Latch/Momentary mode that has been defined for the relay. The difference with a Direct command is On always turns the Relay On and Direct Off always turns the Relay Off (assuming the relay was On when the Direct Off is issued). The Relay will turn Off automatically if in any of the Momentary modes. With Scenes what happens with a Scene On or Scene Off depends on the Momentary mode. Each Momentary mode has a different set of rules as to what Scene On and Scene Off commands actually do. A Scene Off can actually turn the Relay On when in Momentary C mode based on the Sensor status. That is why I suggested using a Direct On as that always turns the Relay On. Link to comment
pintu1228 Posted May 22, 2014 Author Share Posted May 22, 2014 I will check again and post my results, Thanks Link to comment
pintu1228 Posted September 2, 2014 Author Share Posted September 2, 2014 So I managed to get it working by soldering two wires on a spare liftmaster 883lm remote. It works a couple of times and then stopped working displaying this. How can I fix this error? Thanks Link to comment
Brian H Posted September 2, 2014 Share Posted September 2, 2014 Is 28.9C.AB the Insteon ID for the Garage Door I/OLinc? Link to comment
oberkc Posted September 2, 2014 Share Posted September 2, 2014 This error suggests that something is causing communication problems between the ISY/PLM and the IOLinc. I do not believe this has any relationship to the soldered connection to the remote. Link to comment
pintu1228 Posted September 10, 2014 Author Share Posted September 10, 2014 can you help me setup a button to use in irule just to open/close the garage door? or should I post it in the irule forum? By the way, i got it working perfectly. Thanks Link to comment
oberkc Posted September 10, 2014 Share Posted September 10, 2014 I cannot help with problems specific to irule. for those...yes...probably better luck in irule forum. Link to comment
jedubin Posted June 11, 2015 Share Posted June 11, 2015 Sorry to post in a long-dormant forum, but I'm about to attempt the same solution that pintu1228 did (which I read about on other forums). pintu1228 (or anyone else), any pictures/instructions on how you connected the wires from the IOLinc to the liftmaster 883LM remote would be much appreciated! Thanks in advance. Link to comment
