OutletLink 2473SWH
I am using an 2 OutletLink and I am noticing that the status (on/off) is not correctly displayed in the software. The version of the OutletLinks is v.42. The version of the my console is 4.2.2.
Does anybody know why the OutletLinks do not show the correct status.
Would you explain in detail the situation. The 2473S functions as a Receiver only device so manual operation will not be reflected in Admin Console Status.
I was creating a program that would rely on the status of the module. So if the module status was incorrect the program would not function correctly.
What OutletLinc/device activity occurs when the Status is wrong?
If the device plugged into the controlled outlet is manually operated or turned On/Off with the manual On/Off buttons the Status change is not sent back to the ISY. Note the specs for the OutletLinc Dimmer shows the device functions as a Controller. The specs for the OutletLinc Relay indicates it has no Controller capability.
