Disable a program for a period of time
I want to have a program run and then disable it for 2 hours. Is there a way to do this with a single program? I know I can create a second program and then run a wait, but did not know if there was something I was missing.
I believe this will require a second program.
-Xathros
or put it in its own folder and put the times in folder conditions.
Give some more details on what you are trying to accomplish.
At a generic level, there are several ways to accomplish this.
You can disable a program so that it does not auto start, but still run it from intself. As an example:
Disabled: Equalize
       Status  'Office Light - Office Light / Office Light - Fan High' is not Off
    Or Status  'Closet Light - Closet Light / Closet Light - Fan High' is not Off
    Or $Int_Main.TStat_Status is $Int_Main.TStat_SP.Cool_Actual
    Or $Int_Main.TStat_Status is $Int_Main.TStat_SP.Heat_Actual
       Set 'Main - Thermostat' Fan On
       Wait  10 minutes
       Run Program 'Equalize' (If)
       Set 'Main - Thermostat' Fan Auto
       Wait  10 minutes
This will run every 10 minutes, but will not run when the status of things change because it is disabled.
A, dynamic timer can be had by disabeling the program you want to run, and then placing the start conditions for it including a time since last run to the calling program:
This has the start conditions including last run:
       Status  'Main - Thermostat' > 0% (Humidity)
   And Time is Last Run Time for 'Timer' +  1 minute
       Run Program 'Timer' (If)
This is disabled and will get ran only when those start conditions are true (we can even place more start conditions here if you want:
Or, you can call enable/disable from your scheduler program.
Just to hit one more single program 'disable'
You can use a variable as well.
   And $Int_17 >= 60
       $Int_17  = 0
       Wait  1 minute
       $Int_17 += 1
       Run Program 'Test' (If)
This is similar to the first example where the program is disabled, but calls itself. The difference is that this is enabled (so changes in the status will cause it to run), but the true condition can only be met 60 minutes after the last completion of the Then Path.
