Android Tasker and ISY
Hi,
This is my first attempt on Tasker and it seemed I could not get it right.
http://login:password@192.168.xx.xx/rest/nodes/40070/cmd/DON/
Any expert opinion on this? Thanks.
The "/rest/nodes/..." part has to go in the Path field.
Sent from my SPH-D710 using Tapatalk
Thanks for the reply.
I tried this and it is still not working:
Server:Port
http://username:password@192.168.xx.xx
Path
Am I still missing something? BTW, this rest command works on a browser.
Does that work from the browser on my desktop, I seem to think you have the format wrong off the top of my head but at the wrong computer to check it. You had to have username AND password in there.
Alan
Server:Port
Path
This works from a browser on your phone or only on your computer? Is this phone connected to your local network via WiFi? Otherwise 192.168.xx.xx would not be the correct IP address. Also is "40070" just to disguise your actual device address? It doesn't seem like a correct address normally used.
Yes, the rest command works on a browser of my tablet connected via WIFI. While I am learning tasker, I am not using fqdn so this is within my local network only.
I tested the command on a PC browser, without any issue as well.
To further isolate the problem, I tried doing a curl command on my linux machine and it just worked.
curl -s -u username:password http://192.168.xx.xx/rest/nodes/40070/cmd/DON/
I just noticed now that you are using the HTTP POST action. You need to use HTTP GET.
You're right! Thanks for spotting that.
BTW - rest command could be also in the same line as the URL. No need to use the "path" option.
So if I am not using WIFI and using my Cell network and I dont have an SSL certificate - I understand this is a bit unsecure, below is the command I used but I again, error occurred. Is there an option to ignore SSL?
HPTT Get:
Server:Port
https://username:password@test.dyndns.biz:2000/rest/nodes/40070/cmd/DON/
Unfortunately not. You will need a certificate from a certificate authority. I got one for free from cacert.org.
EDIT: The above statement is no longer correct. With the latest version of Tasker you do not need a certificate from a certificate authority anymore. See the next 2 posts.
I'm interested in this topic.
On your question for SSL, do the following:
Make sure your 443 (or whatever) port is forwarded to your ISY.
On Tasker Action > Net > HTTP GET do the following:
Server:Port = https://USER:PASS@DDNS:PORT
Path = /rest/status/node
At the bottom check Trust Any Certificate.
This should enable you to do your web based connection.
Be sure to test the above in your browser first.
This is an example of two of my programs:
Here we update the status of a fan including a query.
1401224323450
1401419118168
14
Master Fan Status
10
1
118
false
http://USER:PASS@IP:PORT
/rest/query/21 6A 24 2
118
false
/rest/status/21 6A 24 2
547
%masterfan_httpd
%HTTPD
590
%masterfan_httpd
formatted="
590
%masterfan_httpd2
547
%MasterFan
%masterfan_httpd21
547
%MasterFan
Error
%masterfan_httpd21
10
*\s*
Next we have a task that changes the Widget to a yellow button while running. It then gets the status of the fan and cycles through Off, High, Med, Low. Last it verifies the state of the fan and changes the widget to be a Black, Red, Silver, Green fan symbol.
1401228917726
1401419519570
15
Master Fan
10
1
549
%MasterFan
152
Master Fan
nn_standby
net.dinglisch.android.ipack.ilikebuttonshd
130
Master Fan Status
%priority+1
35
%MasterFan
8
152
Master Fan
tape_reel2
net.dinglisch.android.ipack.transparentglasshd
%MasterFan
0
Off
152
Master Fan
tape_reel2
net.dinglisch.android.ipack.redgoldpainthd
%MasterFan
0
High
152
Master Fan
tape_reel2
net.dinglisch.android.ipack.glossysilverhd
%MasterFan
0
Med
152
Master Fan
tape_reel2
net.dinglisch.android.ipack.greenfloralhd
%MasterFan
0
Low
152
Master Fan
cust_warning
%MasterFan
0
Error
130
Master Fan Status
%priority+1
35
%MasterFan
8
118
false
/rest/nodes/21 6A 24 2/cmd/DON/255
%MasterFan
0
Off
118
false
/rest/nodes/21 6A 24 2/cmd/DON/191
%MasterFan
0
High
118
false
/rest/nodes/21 6A 24 2/cmd/DON/63
%MasterFan
0
Med
118
false
/rest/nodes/21 6A 24 2/cmd/DOF
%MasterFan
0
Low
549
%MasterFan
30
hl_zzz_tasker
Wow this is something new and I didn't know about it. I just updated Tasker on my phone & this option is now available there. So I take back what I said before. You do NOT need a certificate from a certificate authority. You can use a self signed certificate. Just check off the "Trust any Certificate" box in Tasker.
You should be aware that trusting any certificate gives you a false sense of security. It leaves you just as potentiality vulnerable as if you have no certificate at all. Any intermediate provider can intercept your connection and recover you credentials without you knowing.
Michael.
Thank you, maddbomber83!
I got it to work with your help.
As I cannot decipher your xml program, did you store the result of ISY /rest/status into a task variable?
I would like to use the variable to determine the next steps of my tasks program.
Correct. You would use the XML split function in tasker. There is also another post that just got a bunch of new posts where the OP has some really nice programs already made and ready for import into tasker that accomplishes the above with some more robustness.
