AT&T to end email-to-text ×
unlinking
I have been playing with commands on my isy interface but have now noticed that on my keypad one button that is not linked to anything controls a light that it should not. Is there a way that I can fix this without doing a hard reset?
I am using a isy controller with a 6 button insteon keypad and the light that it is controlling is a insteon 2477d switch
thank you
You can do it manually (follow the user manual instructions) or do it from ISY.
Try creating a scene that mimics the behavior you are seeing, then delete the scene.
Tried that.. no success ... I am trying to avoid a hard reset because I would have to relink the whole keypad.
any other ideas?
You can do a hard reset of the device, then do a "Restore Device" from ISY, and it will be back to normal.
Or do you have manual links created?  Or using another controller in parallel to ISY?
