Issue with KeyPad Linc Controlling a Scene
I created a scene called "mood lighting" for my kitchen that turns on several devices controlling indirect lights and hanging pendants.  Included in the scene are the devices that control several banks of recessed lights as well as the light over the table.  Within the scence I have set the on level on the recessed lights and the table light to 0% and the one level of the indirects and pendants to 100%.  When I turn the scence on or off from the ISY UI, it works perfectly.  Specifically, the recessed lights and kitchen table light turn off and the indirects and pendants turn on (or stay on if already on).
The issue I am having is that I have a 6 key KeyPad Linc in the kitchen and I set up D key to control the mood lighting scene.  When I attempt to turn the scene on from the KeyPadLinc everything except the kitchen table light works.  In other words, if the table light is off and I turn on the mood lighting scene from the KeyPadLinc, the table light will come on with the indirects and pendants.  The recessed lights turn off as they are to do.
I have removed the kitchn table light from the scene and then re-added it, but the problem persists.
Thoughts?
Along with what Techman is discussing,  the On/.Off levels for the Responders is unique to each Controller.  When the Scene is controlled from the Admin Console the PLM is the Controller and I suspect the Responder On Levels mentioned are when the Scene name was selected with the PLM as Controller.
Click on the Red KeypadLinc button node name just below the Scene name.   Check the Responder On Level values.  These are the values in effect when the KeypadLinc button is the Controller.
LeeG - I am at work and remoted in.  I see exactly what you are saying.  The kitchen light devices where set to 100% within the KeyPadLInc.  I adjusted the KeyPad (actually just copied the scene attributes).  I'll have to wait till I get home and see if things work from the KeyPad, but I suspect they will.
