Can you critique this program - On level dims after 9 pm
Hi,
Need some help getting this program to work:
I want our closet lights to turn on to full brightness during the day (when we turn on the controlling device) and to 50% brightness after 9 pm (again when we turn on switch).
I have a scene called "MBR closet day" which contains the closet lights and has a 100% on level. The MBR closet lights themselves have been set to have a 50% on level.
Right now, the closet lights turn on 100% brightness regardless of time of day.
       From    Sunrise - 30 minutes
       To       9:00:00PM (same day)
   And Status  'MBR Closet' is Off
   And Control 'MBR Closet' is switched On
       Set Scene 'MBR Closet Day' On
Thank you.
blartyo,
If you disable the program, does the light then come on to 50%, or still to 100%? If the latter, have you rebooted the switch (pull air gap tab out for a few seconds) since setting the local on-level to 50%?
