How to restore erased a EZflora control
Hi
A while back I erased one of my control outlest on EZflora (I did not havea need for it then, and did not want it to show up).  Now I would like to restore it.  Is there an easy way to restore it wittout reinstalling EZflora.  E.g. I erased the control of port5, so only port 1-4 and 6-8 show.  How do I get port5 to show?
Chris
Edited by Panda88
Restoring an ISY Backup taken just before that node was deleted if no other changes have been made to the ISY environment.
Otherwise the EZFlora has to be Deleted and added back to get the deleted node back.
If I use a backup to enable it, can I then go back and restore a new backup afterwards (where I am now) and still have the node remaining?  I have too maby changes after then removal for it to make sense unless above works
No.  Restoring a later ISY Backup will lose the new node.
The only option is to Delete the EZFlora and add it back.
Edited by LeeG
