isy-99i Secondary Buttons on KeypadLinc 2334-232
I recently purchased a KeypadLinc 2334-232 (6 Button, dual band).
When I linc the KPL to ISY, MyISY identifies the KPL correctly, but only shows one line for the controller.  It should show 5.
How do I link the secondary buttons?
Any help is greatly appreciated.
Firmware:  3.3.10
UI:  4.2.10
Log from linking:
Fri 09/12/2014 05:36:53 PM : Start Insteon Device Linking Mode
Fri 09/12/2014 05:36:53 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 09/12/2014 05:37:01 PM : [LNK-STAT    ] 02 53 M(01) gid=00 2F.EE.D7 0142 43
Fri 09/12/2014 05:37:01 PM : [2F.EE.D7 00] Linked device type=01.42 fw=43
Fri 09/12/2014 05:37:01 PM : [2F EE D7 0  ] Added to list of devices to link to ISY
Fri 09/12/2014 05:37:01 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 09/12/2014 05:37:10 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 09/12/2014 05:37:10 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 09/12/2014 05:37:10 PM : [iNST-TX-I1  ] 02 62 2F EE D7 0F 0D 00
Fri 09/12/2014 05:37:10 PM : [iNST-ACK    ] 02 62 2F.EE.D7 0F 0D 00 06                 (00)
Fri 09/12/2014 05:37:11 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 0D 02           (02)
Fri 09/12/2014 05:37:11 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:11 PM : [2F EE D7 0  ] Calibrating engine version
Fri 09/12/2014 05:37:11 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Fri 09/12/2014 05:37:11 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Fri 09/12/2014 05:37:12 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:12 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:12 PM : [iNST-ERX    ] 02 51 2F EE D7 2F BA B2 11 2F 00 00 01 0F FF 00 AA 00 2F BA B2 00 1E 01 5E
Fri 09/12/2014 05:37:12 PM : [Ext-Direct  ] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 09/12/2014 05:37:13 PM : [2F EE D7 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Fri 09/12/2014 05:37:13 PM : [2F EE D7 1  ] Start : Adding device to ISY
Fri 09/12/2014 05:37:13 PM : [2F EE D7 1  ] Finish : Adding device to ISY was Successful
Fri 09/12/2014 05:37:13 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1
Fri 09/12/2014 05:37:13 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Fri 09/12/2014 05:37:13 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2E 00           (00)
Fri 09/12/2014 05:37:13 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:14 PM : [iNST-ERX    ] 02 51 2F EE D7 2F BA B2 11 2E 00 01 01 00 00 20 20 1E FF 05 3C C0 00 00 00
Fri 09/12/2014 05:37:14 PM : [Ext-Direct  ] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 09/12/2014 05:37:14 PM : [iNST-TX-I1  ] 02 62 2F EE D7 0F 19 00
Fri 09/12/2014 05:37:14 PM : [iNST-ACK    ] 02 62 2F.EE.D7 0F 19 00 06          LTSREQ (LIGHT)
Fri 09/12/2014 05:37:14 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 01 00           (00)
Fri 09/12/2014 05:37:14 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:14 PM : [2F EE D7 0  ] Successfully added device
Fri 09/12/2014 05:37:15 PM : [  2F EE D7 1]       OL 255
Fri 09/12/2014 05:37:15 PM : [  2F EE D7 1]       RR  30
Fri 09/12/2014 05:37:15 PM : [  2F EE D7 1]       ST   0
Fri 09/12/2014 05:37:15 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 02 0F FF 08 A2 00 2F BA B2 FF 1F 01 5D
Fri 09/12/2014 05:37:15 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 02 0F FF 08 A2 00 2F BA B2 FF 1F 01 5D 06        (00)
Fri 09/12/2014 05:37:15 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:15 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:15 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 2F EE D7 01 42 43 15
Fri 09/12/2014 05:37:15 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1
Fri 09/12/2014 05:37:16 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 02 0F F7 08 00 00 00 00 00 00 00 00 C1 06        (00)
Fri 09/12/2014 05:37:16 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:16 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:16 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Fri 09/12/2014 05:37:16 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06        (00)
Fri 09/12/2014 05:37:17 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:17 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:17 PM : [iNST-ERX    ] 02 51 2F EE D7 2F BA B2 11 2F 00 00 01 0F EF 20 00 18 2F BA B2 FF 1F 01 E0
Fri 09/12/2014 05:37:17 PM : [Ext-Direct  ] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 09/12/2014 05:37:17 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Fri 09/12/2014 05:37:17 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06        (00)
Fri 09/12/2014 05:37:18 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:18 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 09/12/2014 05:37:18 PM : [iNST-ERX    ] 02 51 2F EE D7 2F BA B2 11 2F 00 00 01 0F EF 20 00 18 2F BA B2 FF 1F 01 E0
Fri 09/12/2014 05:37:18 PM : [Ext-Direct  ] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 09/12/2014 05:37:18 PM : [iNST-TX-I2CS] 02 62 2F EE D7 1F 2F 00 00 02 0F EF 08 00 18 2F BA B2 FF 1F 01 F7
Fri 09/12/2014 05:37:18 PM : [iNST-ACK    ] 02 62 2F.EE.D7 1F 2F 00 00 02 0F EF 08 00 18 2F BA B2 FF 1F 01 F7 06        (00)
Fri 09/12/2014 05:37:19 PM : [iNST-SRX    ] 02 50 2F.EE.D7 2F.BA.B2 2B 2F 00           (00)
Fri 09/12/2014 05:37:19 PM : [std-Direct Ack] 2F.EE.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
The 3.3.10 release does not support the Dual Band KPLs.  The Dual Band KPLs became available well after 3.3.10 was released.  Need to move to a 994i.
