isy 994i device status update fail
raderu
hello....my isy 994i would not update status of switch link ( ON or OFF ) on the dash board if used actual wall switch link.its requires manual refresh to update status of switch link Only updates status if used written programs or use dash board to switch that link ON or OFF...please advise...
If the SwitchLinc is the only device not reporting manual changes right click on node and select Restore Device.   It sounds like the SwitchLinc has lost its link database.
If many devices are not reporting manual changes then it is more likely the PLM has lost its link database.    A File | Restore Modem (PLM) would be the first thing to try.
one thing i forgot to mention : i just replaced my PLM with the new since old one stopped working.....May be it is special procedure  to i missed to hook it up properly?....because my "refresh " issues started after this...
i tried to file/restore PLM...it did not help
tried follow those steps.....tried restore PLM....still same result : if use any switch link ( i have over 20 of them ) it will not update status unless manually refresh....other options?....and this happened after i replaced PLM...
