Insteon LED doesn't work with "On" only "Fast On"
Any idea why one of my LED's would do this?  If I press On in the admin console, or set motion, or timers or anything to make the light go On, it never does.  It shows status is Off and never tries to turn on.  If I do Fast On it works fine, or any dim level, and Off as well as Fast Off work, just On does nothing.  Any idea what might cause that or where to troubleshoot?  Very strange!
On Level Applied Locally set to Zero?
-Xathros
Yes that was it!  I didn't even know what that field did, set it to 100 and it works now thanks!
Anytime!  Happy to help.
-Xathros
That's the only negative I have with the Insteon LEDs, if you have them Off and remove them, they stay off even if you move them to a different house.  So unless you leave them on and then unplug them, they can't be used as normal lights somewhere else.  Found that was a pain when moving them, as I'd have them turned off, then want to move one into maybe a closet which was dark, so removing the old bulb would leave you in the dark and putting in the new one would as well!  Be nice if maybe turning the load on and off 5 times within 5 seconds would force it on or something as a backup.
