Cannot link Leak Sensor to ISY-994i
flynifr
I have a small Insteon setup in my home including about a dozen switchlincs, a few appliancelincs, 2 access points, and 2 motion sensors.  None of my devices including the PLM are dual band but the motion sensors are linked through the access points.
I am trying to install a leak sensor but without any luck.  When I try linking be entering the address, and device type I get an error 9 "cannot determine link table".  When I use address and auto discover I get "cannot determine device type" Error -2.
Here is the level 3 log of one attempt with the sensor sitting on top of the access point in link mode with the green light flashing:
Mon 11/17/2014 22:02:19 : [27 a1 62    ] Added to list of devices to link to ISY
Mon 11/17/2014 22:02:19 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 0D 00
Mon 11/17/2014 22:02:19 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00)
Mon 11/17/2014 22:02:28 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 0D 00
Mon 11/17/2014 22:02:28 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00)
Mon 11/17/2014 22:02:38 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 0D 00
Mon 11/17/2014 22:02:38 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00)
Mon 11/17/2014 22:02:38 : [iNST-SRX    ] 02 50 27.A1.62 0C.A5.57 23 0D 02           (02)
Mon 11/17/2014 22:02:38 : [std-Direct Ack] 27.A1.62-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Mon 11/17/2014 22:02:38 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 10 00
Mon 11/17/2014 22:02:38 : [iNST-ACK    ] 02 62 27.A1.62 0F 10 00 06          ID-REQ (00)
Mon 11/17/2014 22:02:39 : [iNST-SRX    ] 02 50 27.A1.62 0C.A5.57 27 10 00    ID-REQ (00)
Mon 11/17/2014 22:02:39 : [std-Direct Ack] 27.A1.62-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Mon 11/17/2014 22:02:48 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 10 00
Mon 11/17/2014 22:02:48 : [iNST-ACK    ] 02 62 27.A1.62 0F 10 00 06          ID-REQ (00)
Mon 11/17/2014 22:02:57 : [iNST-TX-I1  ] 02 62 27 A1 62 0F 10 00
Mon 11/17/2014 22:02:57 : [iNST-ACK    ] 02 62 27.A1.62 0F 10 00 06          ID-REQ (00)
Mon 11/17/2014 22:03:01 : [27 A1 62 0  ] Calibrating engine version
Mon 11/17/2014 22:03:01 : [iNST-TX-I2CS] 02 62 27 A1 62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Mon 11/17/2014 22:03:01 : [iNST-ACK    ] 02 62 27.A1.62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Mon 11/17/2014 22:03:08 : [iNST-ERX    ] 02 51 27 A1 62 0C A5 57 17 2F 00 00 01 0F FF 01 00 00 00 00 00 00 00 00 C1
Mon 11/17/2014 22:03:08 : [Ext-Direct  ] 27.A1.62-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Mon 11/17/2014 22:03:10 : [iNST-TX-I2CS] 02 62 27 A1 62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Mon 11/17/2014 22:03:10 : [iNST-ACK    ] 02 62 27.A1.62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Mon 11/17/2014 22:03:19 : [iNST-TX-I2CS] 02 62 27 A1 62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Mon 11/17/2014 22:03:19 : [iNST-ACK    ] 02 62 27.A1.62 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Mon 11/17/2014 22:03:23 : [27 A1 62 0  ] Failed to add device, reason 9
Mon 11/17/2014 22:03:23 : [All         ] Writing 0 bytes to devices
Bad COM's, bring the sensor to the AP and press and hold the linking button in the sensor till it flashes.
Use the ISY to enroll the sensor while entering the address.
Encrypted By: Phoenix Security Solutions
I am on 4.2.18 on the ISY and software.  Everything else in my network is working fine.  I do have an old PLM however, probably 4 years or more.  Could that be the problem.  I have motion sensors working so I doubt it.
Is the PLM a 2412 (no RF capability) or a 2413 which does have RF.
From the trace it looks like the PLM is a 2412.   It took three attempts before the Leak Sensor responded.  The motion sensor is likely talking through one of the access points.
Mon 11/17/2014 22:02:19 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00) attempt one, no response
Mon 11/17/2014 22:02:28 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00) attempt two, no response
Mon 11/17/2014 22:02:38 : [iNST-ACK    ] 02 62 27.A1.62 0F 0D 00 06                 (00) attempt three, Hops Left=0
      37.3k
      373.4k
