Query Resets Keypadlinc Buttons Status in ISY
I am using a Keypadlinc to control the behavior of programs.
I noticed that a Query command resets the status of the On buttons back to Off in the ISY.
The buttons in the physical Keypadlinc remain on, but I understand that.  I need a scene to turn them on/off from the ISY.
However, I don't understand why the Query command resets the status of the On buttons back to Off in the ISY.
Thoughts?
P.S.:  This behavior occurs on both 4.0.5 and 4.2.18
bbconvert-
What are you querying?  The Primary node (ON/Off for a KPL6 or A for a KPL8) or one of the secondary nodes?  I believe when querying a multi-node device, you should always query the primary node and the ISY will update the status for all of the device's nodes at once.
-Xathros
Edited by Xathros
Hi Xathros,
I am querying "A" on a KPL8 via program.
Thanks, Antonio
Antonio-
I am unable to duplicate that behavior here.
I highly suspect program involvement.  On the Programs Summary tab, sort by last run time.  Query your KPL and then look to see if any programs were triggered as a result.  Analyze any programs that react to the query to see if they may be turning off the KPL button(s)
-Xathros
Edited by Xathros
