Query All and Zwave?
Yes it does.
If you want to test, set your event viewer at level 3 communications then go to your query program, right click and select "Run Then" and watch it ping all your devices. The kind of exercise our wives would shake their head at.. but at some level makes us happy :)
Thanks. I have a schlage deadbolt and had looked at logs for couple days after installing and didn't see it. Will look again and/ or test.
Related: is there any way to exclude a device from 'Query All'? The echolink zwave tilt sensor is not queryable - but ISY keeps trying to query it - causing a UI error each day.
Hi MWareman,
There is currently no way of excluding a device from 'Query All'.  An alternative you could try would be to put all the devices you do want to query in one or more scenes, and just query those scenes.
Hi MWareman,
OK, thanks. I'll do that when I get a chance.
Michael.
