Intensity of Keypad LED
I found a pic of a Keypad and noticed the LED on one of the buttons has a higher intensity that the others.  Anyone know how to control the level of brightness of the LED via the ISY?
Edited by k5map
There's a "LED Brightness" button at the bottom of the screen when you've selected any KPL button. It brings up a dialog to set the on and off state brightness levels. You can set it in steps from 0..7.
You can also set the backlight level in a program.
ergodic,
Thanks for the info... do you have an example of how to set the backlight in a program?  I'm thinking of controlling the level based on the time of day and any example would be greatly appreciated.
All buttons on a KPL have the same intensity, that is, you cannot adjust the brightness of only one particular button.  It appears that the top left button is On and the others are Off. If the other buttons can toggle between On and Of and that button is always On, then it's set for non-toggle on.
k5map, I use a scene that includes the KPL buttons as responders and a program that turns the scene off.
        Time is  x:00:00AM
        Set 'LR / Devices / LR Thermostat Main' Mode Off
        Resource 'BR Sheer/Opaque Close'
        Set Scene 'BR / Scenes / BR Fireplace' Off
        Set Scene 'DR / Scenes / DR Front Off Button' Off
   - No Actions - (To add one, press 'Action
The DR Front Off Button scene all includes the KPL buttons I want turned off
Edited by stusviews
stusviews,
Thanks... I thought your program could change the brightness setting of the buttons but now see how to turn the button lights On/Off.
k5map,
If you want to adjust the on and off levels of the KPL backlight you could do it in program. This affects all the buttons on the KPL.
This program dims the backlight at Sunset and brightens it at sunrise.
  From Sunset
  To      sunrise (next day)
     set 'KPL name' On 3 / Off 2 (Backlight level)
     Set 'KPL name'  On 8 / Off 2 (Backlight level)
Edited by Techman
Techman,
Thanks... that's exactly the program I wanted.
Here is mine, although maybe I will change it to go on at sundown.  I have a "sleep" button that turns off bathroom and bedroom lights and the KPL backlight.:
        From     8:35:00PM
        To      11:00:06PM (same day)
        Set 'Master Bedroom / Master Bedroom Devices / Master His KPL - A lights' On 10 / Off 5 (Backlight Level)
        Set 'Master Bedroom / Master Bedroom Devices / Master His KPL - A lights' On  7 / Off 0 (Backlight Level)
