ISY isn't showing me the Internet Address
I noticed today, that I had trouble enabling the internet acess on the ISY. Then after shuting the router off, and unpluging the ISY, I was able to get it to work.
When I go under help, the internet address is http:/0.0.0.0/
Any idea what I am doing wrong?
Hi AnthemAVM,
You are not doing anything wrong: ISY is asking your router for the external IP address to which your router is responding with 0.0.0.0. Perhaps you should reboot your router one more time!
Hi Michael,
I rebooted the router, and still nothing showing up.
I went to my cell phone and pulled up the short cut to the ISY via the IE, and it went right there. So things are working, just not the ISY to Router.
Any other ideas, what I might not have set correctly?
Hello AnthemAVM,
Have you setup ISY using File->Enable Internet Access or have you done it manually?
Hi Michael,
Michael,
I have done the file-enable internet access, I was having trouble getting the ISY to do it. It gave me a bunch of failed attempts. So I unplugged the ISY and Router, and then it allowed me to do it.
The weird thing is I can go to the spepicific Https://address.com and get into the ISY.
