Schedule Button for Thermostat Adapter Device
Hi there,
I noticed in the latest UI/Firmware version installed that there's a new button called "Schedule" which appears under the Thermostat device adapter node. It doesn't function for me; I get a subscriber no reply error when the button is pressed.
What's the function of this button?
Which thermostat do you own?  This function has been in the code for quite some time, but only was implemented for specific thermostats that allow us to remotely update schedules.
I have a 2441V thermostat adapter, v2.
Before posting this question, I checked the Wiki and found no reference to this button. Can you point me to the page where I can read about this? If the button is not supported for my particular setup, would it make more sense to disable or hide the button, or throw up a context specific error message which indicates this functionality is not supported for the device selected?
Hi matapan,
We'll take at look at that, but not sure what change we will ultimately make.  The 'Schedule' button is currently shown for all the thermostats that support schedules, although thermostats of the same type with older firmware may not actually support schedules.
Just as a data point I have five Venstar 1800 with humidity sensors in place. The ISY Console indicates they are 2441v, using adaptor(s) v.91 / v.92
I also see the schedule button and when pressed see a pop up message indicating: No Network Connection, DHCP state renew.
Edited by Teken
  • 3 weeks later...
Can someone provide some information as to what the Schedule button does?
Can one modify the existing schedule programming built into the thermostat? Or, can one obtain the scheduled programming information from the thermostat to create ISY programs that don't get overridden by the thermostat's own programming if the thermostat is left in the Program mode?
Which thermostats and/or interfaces are supported with this functionality?
+1 Would love to know the details also.
