Insteon Thermostat Fan Program Problems
Hi Guys,
I wrote the following program with the hopes of turning on the fan for different intervals throughout the day
        From     5:00:00AM
        To       8:59:59PM (same day)
        Set 'Thermostat - Main' Fan On
        Wait  15 minutes
        Set 'Thermostat - Main' Fan Auto
        Wait  15 minutes
        Wait  15 minutes
        Wait  15 minutes
        Repeat 15 times
It seems that the program will correctly run the first time (between 5 Am to 5:45 Am) but then does not repeat for the rest of the time.
Can you guys set me straight here or offer me some advice on how to make sure this program will run every hour throughout the day (ie. 5AM, 6AM, 7AM, etc
Am I missing something here?
calberrt
Hi Calberrt
It looks like you want to run the fan for 15 minutes every half hour. Give this a try
        From     5:00:00AM
Repeat every 30 minutes
        Wait  15 minutes
The repeat statement operates on the indented statements below it. As long as the If statements are true, the repeat statement will keep restarting every 30 minutes and run the 3 statements. The else makes sure that the fan really goes off when the program completes
If you want it to run the fan for 15 minutes every hour, change the '30 minutes' to '1 hour'
Paul
Edited by paulbates
Info only: If the HVAC is heating or cooling, setting the fan to Auto will not turn the fan off.
Thanks guys...this worked like a charm.  things are running quite smoothly with the recently purchased 2441th.  Sorted out the fan program (running for 6 hours without a problem) and temps now worked out.  Look forward to may other things to do with the ISY
Calberrt
Glad its working for you
Paul
