Kwikset 914 Zwave deadbolt and ISY994
Hi Folks,
I just got my zwave module and am trying to "include" my lock.  According to the instructions on the lock I merely hold the controller portion of the lock (with the batteries installed) no more than 12" away from the ISY and go into "adding new zwave device" on my ISY.
I have done this, a few times, to no avail.  The ISY just sits there "listening" for a zwave device.
Has anyone paired this particular lock?  Anything I am missing?
Matt
did some more searching - I had to "exclude" it first, and the it included perfectly fine.
Works great!!!  :)
Matt
Just FYI, I have 2 of these that I installed in March of last year and they both have 50% battery left. I have had no issues with either of my locks. I'm actually impressed with how long the batteries have lasted.
Q
  • 1 month later...
HI Folks - another issue - all of a sudden ISY has lost communication to my lock - they are about 15 feet apart in an open room.
I have tried excluding the device (so I can re-add it) - but that refuses to work, and when I "add" the device it says it has updated it - but still no status or communication.
What should I check next?
As far as I know - nothing has changed at all unless my ISY auto upgraded itself - I am at 4.2.18
TIA,
Matt
I was finally able to remove it- and when I readd it (after a fresh reboot) i get this error log and the device shows up as "uninitialized".
Fri 02/13/2015 07:07:05 PM : Listening for Z-Wave devices to add to the network
Fri 02/13/2015 07:07:09 PM : Adding Z-Wave devices stopped
Fri 02/13/2015 07:07:20 PM : Listening for Z-Wave devices to add to the network
Fri 02/13/2015 07:07:26 PM : Z-Wave device detected, retrieving info 2
Fri 02/13/2015 07:07:26 PM : Z-Wave device detected, retrieving info 3
Fri 02/13/2015 07:07:27 PM : Z-Wave device detected, retrieving info 5
Fri 02/13/2015 07:07:28 PM : Adding Z-Wave devices stopped
Fri 02/13/2015 07:07:28 PM : Exchanging data with secure Z-Wave device 2 of type 4.64.3
Fri 02/13/2015 07:07:28 PM : Adding secure Z-Wave device
Fri 02/13/2015 07:07:59 PM : [ZWAVE-ADDSECURE] Error 11
Fri 02/13/2015 07:07:59 PM : Failed to include secure Z-Wave device 2 of type 4.64.3
Fri 02/13/2015 07:07:59 PM : [ZWAVE-DB        ] Unexpected NULL database for uid=2 0x02
Fri 02/13/2015 07:07:59 PM : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 2 (0x02) ----
Fri 02/13/2015 07:08:02 PM : [ZWAVE-DB        ] Unexpected NULL database for uid=2 0x02
Fri 02/13/2015 07:08:20 PM : [ZWAVE-DB        ] Unexpected NULL database for uid=2 0x02
Fri 02/13/2015 07:08:23 PM : [ZWAVE-ADD-NODE  ] *Failed: Get Security Commands Report failed
Fri 02/13/2015 07:08:23 PM : [ZWAVE-NODE-SYNC] -- Finished -- ISY/Z-Wave Node Sync --
Fri 02/13/2015 07:08:24 PM : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 2 (0x02) ----
Fri 02/13/2015 07:08:32 PM : [ZWAVE-NODE-SYNC] -- Finished -- ISY/Z-Wave Node Sync --
Next steps or ideas?
Matt
Factory reset done - lock is still acting the same way - just can't get it to pair up.  Let me open a case with Kwikset.  I can already feel them telling me that it must be my controller.
Matt
I have a Kwikset lock and when I first installed it I was having issues with communication , it kept failing and I would have to exclude and add it multiple times. I searched the forums and found that someone had posted about the position of the external antenna could be a factor. I moved the antenna from a vertical position to a horizontal position and my lock has worked flawless since.
I am using the internal antenna - and am literally 10 feet away.  But I can't even get it to pair anymore.  I will call Kwikset tomorrow and see how that goes and post back.
Matt
I just installed my first kwikset 916 lock and at first I couldn't get it to include.  After reading this post, I excluded it - then included it and that worked find.  In addition, however, I also did the ""Advanced - Update Z Wave Firmware" option in the ISY.  This might help you as well.  After that, including worked mostly fine (once it didn't include - but excluded again and then include worked).
Good luck.
Mark
