Network Module without PLM
Okay, I know someone has to have covered this before... but after a number of searches and lots of false hits.. here goes:
My PLM died.  Dead.  Taps.  Ordered new one.  Delivery: Next Monday :(
I have some functions that use programs, variables and the network module.  No Insteon function at all.  However, I now have no programs are running at all (the my programs folder is empty) .  I can still see state variables being updated, etc.
Is this by design (and if so, why?) and if not, how do I fix it between now and Monday?  Is it due to 'safe mode' which is entered due to no PLM?
Detail:  My Autelis bridge and Dataloggers DIN rely on the network module and programs to run my heating.  Having or not having a PLM is irrelevant to that automation.
50/50
Thanks.  I was running 4.2.17 when the PLM died.  I just grabbed the 4.2.18 from the link above.  Is this different than the "normal" firmware?  Do I need to reload to "standard" when a new PLM arrives?
Yes, once the PLM arrives you need to load the standard firmware and follow the wiki for replacing the PLM.
Loaded 4.2.18 from this link.  I'm stuck.  Can not log in.  ISY RX/TX lights  on solid.  I get the Admin Console but "File->Logon" is greyed out and all tabs are empty (Main/Program/Configuration).
A little worried...
http://isy.universal-devices.com/updates/Isy_UD994/
Pick your version.. Doesn't require PLM
Sorry for brevity - posted using mobile Tapatalk
50-50,
I am going to be calling you shortly.
