Setting on-level for a group (scene)
For some reason, the following code fragment does not work:
return changeGroupState(InsteonConstants.DEVICE_ON, Integer.toString(onLevel), address);
The idea is to set the scene address to the onLevel specified. The scene does turn on, but always to full brightness (or perhaps, I would think, to the default brightness for that scene). Isn't there a way to send a preset dim level to a scene the same way I can send a preset dim level to an individual device?
Insteon does not support this. Scene commands are On, Off, Brighten, Dim, Fast On, Fast Off.
A scene could contain hundreds of devices, each of which has a level and ramp rate unique to that scene. Hundreds of scenes are available. Using the ISY-26 it is easy to create another scene with the on levels and ramp rates you desire with your preset dim levels.
Rand
siegeld,
Unfortunately, INSTEON does not allow sending preset dim levels to a scene. As per philosophy: that's why each device belonging to a scene already has a preset DIM associated with it!
We would've it loved if your scenario worked as we do get a lot of requests for that functionality.
