How to determine how many devices/scenes I am using
I know I can generate a topology report, which lists every node and every program, but is there an easier way than to manually count each node line by line?  I have about 80 devices and if you count each node under each device (e.g. 8 for a KPL), and add all the scenes, I am worried I might be running up against the 256 limit (for non-pro version).
Edited by blueman2
Tools, Diagnostics, Show PLM Links Table
Thanks.  That shows 344 items.  So I am already over the limit for non-pro version?
I did a manual count of all nodes (devices and scenes, including for example all 8 buttons on a KPL) and came up with closer to 210.  Something seems off, at least in terms of what ISY counts as devices/scenes.  ??
I believe the number is devices and Scenes, not the the number of devices being used in Scenes.
I thought the 256 limit was for total of scenes AND device nodes.  Or is it scenes OR device nodes?
Edited by blueman2
It is nodes and Scenes.   Not nodes and Scenes and the number of nodes in Scenes.
Edited by LeeG
Ah, now I see where the 344 number came from.  So that method does not help me.  So as far as my original question, is there any way to do that math aside from manually counting each node and scene?  Doable, but since this is an important licensing issue, I thought there might be a more simple way to see how close I am to needed to upgrade to Pro version.
Edited by blueman2
Hi blueman2,
Unfortunately not. If you have 344 plm links and your scenes have an average of 10 nodes, I would say you are in low 100s.
Fuzzy math? Sorry, I was trying to wrap my head around this and I think I had too much caffein this morning. :-)
~Mike
