Need advice on controlling RF devices
Hello All,
 I'm new here.  I'm still learning the programming of my ISY994i.  Hope someone can give me advice.  I have the ISY994I and Insteon Dual-Band PLM.  I have motorized shades made by rollertrol.com that are controlled via RF remote.  Would it be possible to be able to schedule ON\OFF(roll-up\down) via my ISY994i?  Do I need to add an RF module to my ISY994i device?
Thanks All
I see that there is a universal interface available for the rollertrol blinds.  It seems that would interface will with an insteon IOlinc.  I see also a usb dongle RF controller available and claims that this can be accessed via a vera controller.
Based on my own experience, I assume that this dongle would be available to the ISY through the network module, but may require abilities to communicate via some REST or HTML or other interface with which I have yet to personally use.  I don't believe that there is a plug-and-play solution here.
The RollerTrol Universal Motor Interface can be use with an Insteon compatible EZIO 4 Input/2 Output Relay Controller.
Thanks for all your suggestion.  I will look into your suggestions and let you know the outcome.
