Device / Program / Variable and Where Used
Not sure if this has been asked before, but couldn't locate it....
Is there a way to identify where a variable is being used?  or Device?  or Program?
For example, if I have a variable that I'm not sure where it is being used, how do I locate?
If I had a Device that I wanted to remove....  how do I locate all programs it is being used in?
etc.
etc.
You can right click on any of your programs and select Find/Replace, use that to search for your Raw text, variable, device, scene or program name.
For scene membership, simply select the device in the tree and look at the right side of the screen to any scenes that it controls or responds to.
-Xathros
Edited by Xathros
That will work !   A couple of days ago I removed a variable that I thought was no longer needed...  days later I remember it's purpose...  using the Find feature will prevent this mistake again.
Anytime!  Happy to help.
-Xathros
