Program for 2 motion sensors
Getting stuck making this work.  In my bathroom I have 2 motion sensors, one that covers all the bathroom, then a second aiming right at the shower to prevent it from turning off when someone is in there.  I set it low, to turn off after 2 minutes.  It works to keep the light on but what's the best way to turn the light off after 2 minutes of no motion at all?  My programs are below but the Off one doesn't work, light never turns off I guess since the way I have it means both have to go off at the same time.  I feel like this is easy but mind is blank, thanks!!!
Motion On
Master Bath Motion On - [iD 0023][Parent 0025]
        Control 'System Devices / Master Bedroom and Bath / Motion Sensor-Sensor' is switched On
     Or Control 'System Devices / Master Bedroom and Bath / Z-Wave Shower Motion Sensor' is switched On
        Set Scene 'Scenes / Master Bathroom and Shower' On
Motion Off (Doesn't work, only with 1 sensor it does)
Master Bath Motion Off - [iD 0024][Parent 0025]
        Control 'System Devices / Master Bedroom and Bath / Z-Wave Shower Motion Sensor' is switched Off
    And Control 'System Devices / Master Bedroom and Bath / Motion Sensor-Sensor' is switched Off
        Wait  2 minutes
        Set Scene 'Scenes / Master Bathroom and Shower' Off
Edited by edokid
Use "If Status" for the Off check.  If Control ..... is switched Off does not And well.  There will not be two Off commands received at the same time but  there will be If Status Off for both at the same time.
I have the same setup in my bathroom. I set my motion detectors to "On only" mode and paired them with the lights. Then an ISY program turns off the lights if no "On" command has been sent from either detector within 15 minutes.
Edited by aliensk8terboy
Or, you could narrow this down to one program:
Motion On
Master Bath Motion On - [ID 0023][Parent 0025]
        Wait 2 minutes
In this program, the wait restarts with each new Motion On received and will timeout and turn off the lights after 2 minutes with no motion detected.
Hope this helps.
-Xathros
Edited by Xathros
Great thanks everyone, I can't remember why I did it as 2 programs.  I was removing things to make it simple but the actual program has schedules on it like it only runs during the day and not middle of the night etc.
