Can not add some KPLs.
I am having problems adding *some* KPLs to my new ISY 99 (FW V2.6.5).
I have about ten KPLs (V1.4 to V1.8) and only half of them have been successfully added. I've had no problems adding any other Insteon device (from switchLincs to in-line lincs to outletlincs). I've been selecting "New INSTEON Device" from the "LinkManagement" pull-down menu.
I've moved my PLM three times to try to help the PLM see these KPLs. In one case, I've actually swapped KPLs and it seems the problem followed the KPL.
At this point, I'm at a loss to solve this and need some help. What's so special about these KPLs?
Here a snippet from the Event Viewer:
2008/10/16 15:38:18 : ---- Initializing the linked devices ----
2008/10/16 15:38:18 : ---- All Linked Devices are now initialized ----
2008/10/16 15:38:18 : ---- Add remaining devices ----
2008/10/16 15:38:18 : [ 9 90 54 1] Removing all links
2008/10/16 15:38:19 : [ 9 90 54 1] Adding device to ISY
2008/10/16 15:38:45 : [ 9 90 54 1] ** Not Added ** Restore node Failed
2008/10/16 15:38:45 : ---- All Remaining Device Added ----
2008/10/16 15:41:02 : ---- Initializing the linked devices ----
2008/10/16 15:41:02 : ---- All Linked Devices are now initialized ----
2008/10/16 15:41:02 : ---- Add remaining devices ----
2008/10/16 15:41:02 : [ 9 87 E5 1] Removing all links
2008/10/16 15:41:04 : [ 9 87 E5 1] Adding device to ISY
2008/10/16 15:41:27 : [ 9 87 E5 1] ** Not Added ** Restore node Failed
2008/10/16 15:41:27 : ---- All Remaining Device Added ----
I figure "Restore node Failed" is important, but I have no idea what that means.
Any ideas?
Paul
Hello Paul, and welcome to the forum.
Do all the KeypadLincs which are failing, have the same version (eg 1.8 ), or do they vary?
Hi Darrell,
I took an inventory of every KPL I have and here is what I found:
Name Address Version Added to ISY?
KPL1 07.f3.e4 1.4 Success
KPL2 09.8c.44 1.4 Success
KPL3 0a.b3.5b 1.5 Failed
KPL4 09.90.54 1.6 Failed
KPL5 09.87.e5 1.6 Failed
KPL6 0e.2a.4b 1.8 Success
KPL7 0e.2e.9a 1.8 Success
KPL8 09.9b.2b 1.4 Success
KPL9 0a.df.2e 1.6 Failed
KPL10 0a.df.3a 1.6 Failed
So, it looks like every V1.5 and V1.6 failed while every V1.4 and V1.8 passed. Yikes!
-Paul
Hello Paul,
One more question: are you using Start Linking method or Add a New INSTEON Device? In either case, would you try Add a New INSTEON Device and choose the device type (KPL) from the drop down? If this works, then we know the problem: they are not responding with IDReq (which was quite prevalent in 1.5 and 1.6 and thus the introduction of 1.65 in a matter of weeks!).
Hi Darrell,
-Paul
Hi Michael,
That worked. I had been using the "Add INSTEON Device" menu option from the pull-down, but had been doing the "Auto Detect". When I specified Keypadlinc Dimmer as the device type, everything fell quickly into place - all of my KPLs have now been added.
I suppose that I was "lucky" to score four of these tight-lipped V1.6 KPLs :)
Do you know if there are any other gatchas that I can expect with the these V1.5 and V1.6 KPLs? Or, is the lack of the IDReq only significant during the initial discovery?
Thanks for your help,
Paul
Hi Paul,
We have experienced many more problems especially with 1.5:
Christmas effect: random/ghost like activation of devices linked to it
Missing link effect: random corruption of the link database
Hi Michael,
Paul
