Scene cross contamination question
Hi Folks,
This might be an easy one to answer, but I couldn't quite figure it out.
I have a pretty simple set up with quite a number of insteon devices and the 994.  In my daughters room I have a keypad and a fanlinc that controls the light, and the 4 speeds of the fan (low, medium, high, off).  I have 5 scenes for this - and each scene has the associated button or fanlinc toggle, along with the button on the keypadlinc.
I have been wracking my brain trying to figure out why my backyard lights (outletlinc) turn off before 9pm like they are supposed to... and i finally figured it out.
The Scene "Kids Bedroom Light" (which has FanLink light resource along with button on the keypadlinc) works fine - but it ALSO triggers the outletinc outside.
I have no idea why this is happening - the outletlinc was one of the first thing I installed back in the day, and the fanlinc was one of the last things - I don't ever remember linking them together.
How do I remove this association?
Thanks in advance!
Matt
Click on the outletlinc. The right hand panel shows every scene that the device responds to.
Quick fix--add the OutletLinc as a responder to the Kids Bedroom Light scene. Let the ISY write all the links. When it is all done, delete the OutletLinc from the scene, then let the ISY erase all the now-unnecessary links. That should fix it.
It wasn't set up in the list to the right as a responder to any scene other than what it should be - so I took fitzpatri8's advice and added it to the scene and then removed it.  I will post back tonite when I get home and let you know if that worked!
Matt
