Remotes & Keypadlinc
Since updating to release 4.2.22 I no longer have "On" option when programming remotes or keypad buttons.  Only "1 - 100%, Responding and Off" are available options.  All programs that were created with "On" have automatically changed to "100%."  This is weird and somewhat annoying.  Any reason why the latest release changed this?  Thanks
This was done quite a while ago in response to those who use dimmers. Instead of seeing only On, Off, it would show a percentage of on level. But I agree anything that is a relay should only display an option of On/Off because it makes no sense to have 1-100% when the device is not a dimmer.
On 4.2.23 the KeypadLinc Relay shows On in Program
Test1 - [iD 0025][Parent 0001][Not Enabled]
        Status  'ICON Dimmer 1' is not 30%
        Repeat 3 times
           Set Scene 'Scene B' On
           Set 'SwitchLinc Dimmer DB' 100 (Beep Duration)
           Wait  2 seconds
           Set Scene 'Scene B' Off
           Wait  2 seconds
           Set 'KeypadLinc Relay' On
        Send X10 'A1/Off (11)'
