AT&T to end email-to-text ×
Help needed troubleshooting communications issue
Things where working great for a couple of years, and now a few things have popped up.
First, I have my ISY plugged into a 2413S PowerLinc Modem.
I also have (2) 2443 access points.
When I run the beacon test (initiated at the 2413S), both of the access points respond with a flashing green light.
I deleted switch I am having communications problems with. It is a 2476S (15.84.AC) and did a factory reset on it.
Went back and added it back in. Shows as added successfully.
I click the On button in the Admin Console and the light on the load turns on. I click the Off button and nothing happens. At this point I get a message about a communications issue. This switch happens to be a 3 way switch and there is another 2476S on the other end.
I have 28 devices in my house. No filters of any sort. Haven't had any problems to date.
Attached is the Device Communications Event log file.
Any insight would be appreciated. Generally, these things just worked for me (in my current house and last house) so haven't had to do much troubleshooting.
Fri 03/13/2015 11:37:19 PM : [15 84 AC 1  ] Link    1 : 0FF0 [620122FF0E010001] Saving  [62..............]
Fri 03/13/2015 11:37:19 PM : [15 84 AC 1  ] Link    0 : 0FF8 [220022FF0EFF1F01] Saving  [22..............]
Fri 03/13/2015 11:37:19 PM : [MNG-LNK-RSP ] 02 6F 80 E2 00 15 84 AC 02 1C 3A 06
Fri 03/13/2015 11:37:19 PM : [15 84 AC 1  ] Start : Removing device from ISY
Fri 03/13/2015 11:37:19 PM : [15 84 AC 1  ] Finish : Removing from ISY was Successful
Fri 03/13/2015 11:37:20 PM : [All         ] Writing 0 bytes to devices
Fri 03/13/2015 11:37:35 PM : Start Insteon Device Linking Mode
Fri 03/13/2015 11:37:35 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 03/13/2015 11:38:10 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 03/13/2015 11:38:10 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 03/13/2015 11:38:10 PM : [All         ] Writing 0 bytes to devices
Fri 03/13/2015 11:38:18 PM : Start Insteon Device Linking Mode
Fri 03/13/2015 11:38:18 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 03/13/2015 11:38:41 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 03/13/2015 11:38:42 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 03/13/2015 11:38:42 PM : [All         ] Writing 0 bytes to devices
Fri 03/13/2015 11:41:26 PM : [iNST-SRX    ] 02 50 15.84.AC 00.00.01 CB 13 00    LTOFFRR(00)
Fri 03/13/2015 11:41:26 PM : [std-Group   ] 15.84.AC-->Group=1, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:41:26 PM : [iNST-DUP    ] Previous message ignored.
Fri 03/13/2015 11:41:26 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 41 13 01    LTOFFRR(01)
Fri 03/13/2015 11:41:26 PM : [std-Cleanup ] 15.84.AC-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Fri 03/13/2015 11:41:56 PM : Start Insteon Device Linking Mode
Fri 03/13/2015 11:41:56 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 03/13/2015 11:42:07 PM : [LNK-STAT    ] 02 53 M(01) gid=00 15.84.AC 021C 3A
Fri 03/13/2015 11:42:07 PM : [15.84.AC 00] Linked device type=02.1C fw=3A
Fri 03/13/2015 11:42:07 PM : [15 84 AC 0  ] Added to list of devices to link to ISY
Fri 03/13/2015 11:42:07 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 03/13/2015 11:42:17 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 03/13/2015 11:42:17 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 03/13/2015 11:42:17 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 0D 00
Fri 03/13/2015 11:42:17 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 0D 00 06                 (00)
Fri 03/13/2015 11:42:18 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 0D 01           (01)
Fri 03/13/2015 11:42:18 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:18 PM : [15 84 AC 0  ] Calibrating engine version
Fri 03/13/2015 11:42:18 PM : [15 84 AC 0  ] May not fully support i2, reverting to i1
Fri 03/13/2015 11:42:18 PM : [15 84 AC 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Fri 03/13/2015 11:42:18 PM : [15 84 AC 1  ] Start : Adding device to ISY
Fri 03/13/2015 11:42:18 PM : [15 84 AC 1  ] Finish : Adding device to ISY was Successful
Fri 03/13/2015 11:42:18 PM : [15 84 AC 1  ] Link    0 : 0FF8 [A20022FF0EFF1F01] Saving  [A20022FF0EFF1F01]
Fri 03/13/2015 11:42:18 PM : [15 84 AC 1  ] Link    1 : 0FF0 [E20122FF0E010001] Saving  [E20122FF0E010001]
Fri 03/13/2015 11:42:18 PM : [iNST-TX-I2  ] 02 62 15 84 AC 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1
Fri 03/13/2015 11:42:18 PM : [iNST-ACK    ] 02 62 15.84.AC 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Fri 03/13/2015 11:42:18 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2E 00           (00)
Fri 03/13/2015 11:42:19 PM : [iNST-ERX    ] 02 51 15 84 AC 22 FF 0E 11 2E 00 01 01 00 00 20 00 1F FF 00 00 00 3F 0C D1
Fri 03/13/2015 11:42:19 PM : [Ext-Direct  ] 15.84.AC-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Fri 03/13/2015 11:42:19 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 19 00
Fri 03/13/2015 11:42:19 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 19 00 06          LTSREQ (LIGHT)
Fri 03/13/2015 11:42:19 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 01 00           (00)
Fri 03/13/2015 11:42:19 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:19 PM : [15 84 AC 0  ] Successfully added device
Fri 03/13/2015 11:42:19 PM : [D2D EVENT   ] Event [15 84 AC 1] [OL] [255] uom=0 prec=-1
Fri 03/13/2015 11:42:19 PM : [  15 84 AC 1]       OL 255
Fri 03/13/2015 11:42:19 PM : [D2D EVENT   ] Event [15 84 AC 1] [RR] [31] uom=0 prec=-1
Fri 03/13/2015 11:42:19 PM : [  15 84 AC 1]       RR  31
Fri 03/13/2015 11:42:19 PM : [D2D EVENT   ] Event [15 84 AC 1] [sT] [0] uom=0 prec=-1
Fri 03/13/2015 11:42:19 PM : [  15 84 AC 1]       ST   0
Fri 03/13/2015 11:42:19 PM : [All         ] Writing 16 bytes to devices
Fri 03/13/2015 11:42:20 PM : [15 84 AC 1  ] Link    0 : 0FF8 [A20022FF0EFF1F01] Writing [A20022FF0EFF1F01]
Fri 03/13/2015 11:42:20 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:20 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:20 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:20 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:20 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F8
Fri 03/13/2015 11:42:20 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F8 06          PEEK   (F8)
Fri 03/13/2015 11:42:20 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B A2    PEEK   (A2)
Fri 03/13/2015 11:42:21 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:21 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:21 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:21 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F9
Fri 03/13/2015 11:42:21 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F9 06          PEEK   (F9)
Fri 03/13/2015 11:42:21 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 00    PEEK   (00)
Fri 03/13/2015 11:42:21 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:22 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:22 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:22 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:22 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FA
Fri 03/13/2015 11:42:22 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FA 06          PEEK   (FA)
Fri 03/13/2015 11:42:22 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 22    PEEK   (22)
Fri 03/13/2015 11:42:22 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:23 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:23 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:23 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:23 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FB
Fri 03/13/2015 11:42:23 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FB 06          PEEK   (FB)
Fri 03/13/2015 11:42:23 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B FF    PEEK   (FF)
Fri 03/13/2015 11:42:23 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:24 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:24 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:24 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:24 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FC
Fri 03/13/2015 11:42:24 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FC 06          PEEK   (FC)
Fri 03/13/2015 11:42:24 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 0E    PEEK   (0E)
Fri 03/13/2015 11:42:24 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:25 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:25 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:25 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:25 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FD
Fri 03/13/2015 11:42:25 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FD 06          PEEK   (FD)
Fri 03/13/2015 11:42:25 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 00    PEEK   (00)
Fri 03/13/2015 11:42:25 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 29 FF
Fri 03/13/2015 11:42:26 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 29 FF 06          POKE   (FF)
Fri 03/13/2015 11:42:26 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 29 FF    POKE   (FF)
Fri 03/13/2015 11:42:26 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:26 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FE
Fri 03/13/2015 11:42:26 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FE 06          PEEK   (FE)
Fri 03/13/2015 11:42:26 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 1F    PEEK   (1F)
Fri 03/13/2015 11:42:26 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:27 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:27 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:27 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:27 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B FF
Fri 03/13/2015 11:42:27 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B FF 06          PEEK   (FF)
Fri 03/13/2015 11:42:27 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 01    PEEK   (01)
Fri 03/13/2015 11:42:28 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 15 84 AC 02 1C 3A 15
Fri 03/13/2015 11:42:28 PM : [PLM         ] Group   0 : Writing Controller Link matching [15 84 AC 1  ] Link    0 : 0FF8 [A20022FF0EFF1F01]
Fri 03/13/2015 11:42:28 PM : [15 84 AC 1  ] Link    1 : 0FF0 [E20122FF0E010001] Writing [E20122FF0E010001]
Fri 03/13/2015 11:42:28 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:28 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:28 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:28 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:28 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F0
Fri 03/13/2015 11:42:29 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F0 06          PEEK   (F0)
Fri 03/13/2015 11:42:29 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B E2    PEEK   (E2)
Fri 03/13/2015 11:42:29 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:29 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:29 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:29 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:29 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F1
Fri 03/13/2015 11:42:30 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F1 06          PEEK   (F1)
Fri 03/13/2015 11:42:30 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 01    PEEK   (01)
Fri 03/13/2015 11:42:30 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:30 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:30 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:30 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:30 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F2
Fri 03/13/2015 11:42:31 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F2 06          PEEK   (F2)
Fri 03/13/2015 11:42:31 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 22    PEEK   (22)
Fri 03/13/2015 11:42:31 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:31 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:31 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:31 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:31 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F3
Fri 03/13/2015 11:42:32 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F3 06          PEEK   (F3)
Fri 03/13/2015 11:42:32 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B FF    PEEK   (FF)
Fri 03/13/2015 11:42:32 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:32 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:32 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:32 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:32 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F4
Fri 03/13/2015 11:42:33 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F4 06          PEEK   (F4)
Fri 03/13/2015 11:42:33 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 0E    PEEK   (0E)
Fri 03/13/2015 11:42:33 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:33 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:33 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:33 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:33 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F5
Fri 03/13/2015 11:42:34 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F5 06          PEEK   (F5)
Fri 03/13/2015 11:42:34 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 01    PEEK   (01)
Fri 03/13/2015 11:42:34 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:34 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:34 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:34 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:34 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F6
Fri 03/13/2015 11:42:35 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F6 06          PEEK   (F6)
Fri 03/13/2015 11:42:35 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 00    PEEK   (00)
Fri 03/13/2015 11:42:35 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:35 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:35 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:35 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:35 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B F7
Fri 03/13/2015 11:42:36 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B F7 06          PEEK   (F7)
Fri 03/13/2015 11:42:36 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 01    PEEK   (01)
Fri 03/13/2015 11:42:36 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:36 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 15 84 AC 02 1C 3A 15
Fri 03/13/2015 11:42:36 PM : [PLM         ] Group   1 : Writing Responder Link matching [15 84 AC 1  ] Link    1 : 0FF0 [E20122FF0E010001]
Fri 03/13/2015 11:42:36 PM : [15 84 AC 1  ] Link    2 : 0FE8 [0000000000000000] Writing [00..............]
Fri 03/13/2015 11:42:36 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:37 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:37 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:37 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:37 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B E8
Fri 03/13/2015 11:42:37 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B E8 06          PEEK   (E8)
Fri 03/13/2015 11:42:37 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 00    PEEK   (00)
Fri 03/13/2015 11:42:37 PM : [15 84 AC 1  ] Link    3 : 0FE0 : Writing High Water Byte
Fri 03/13/2015 11:42:37 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 28 0F
Fri 03/13/2015 11:42:38 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 28 0F 06          SET-MSB(0F)
Fri 03/13/2015 11:42:38 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 28 0F    SET-MSB(0F)
Fri 03/13/2015 11:42:38 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:42:38 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 2B E0
Fri 03/13/2015 11:42:38 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 2B E0 06          PEEK   (E0)
Fri 03/13/2015 11:42:38 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 2B 00    PEEK   (00)
Fri 03/13/2015 11:42:39 PM : [All         ] Writing 0 bytes to devices
Fri 03/13/2015 11:43:01 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 19 00
Fri 03/13/2015 11:43:01 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 19 00 06          LTSREQ (LIGHT)
Fri 03/13/2015 11:43:01 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 02 00           (00)
Fri 03/13/2015 11:43:01 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:43:01 PM : [D2D EVENT   ] Event [15 84 AC 1] [sT] [0] uom=0 prec=-1
Fri 03/13/2015 11:43:01 PM : [  15 84 AC 1]       ST   0
Fri 03/13/2015 11:43:01 PM : [D2D EVENT   ] Event [15 84 AC 1] [OL] [255] uom=0 prec=-1
Fri 03/13/2015 11:43:01 PM : [  15 84 AC 1]       OL 255
Fri 03/13/2015 11:43:01 PM : [D2D EVENT   ] Event [15 84 AC 1] [RR] [31] uom=0 prec=-1
Fri 03/13/2015 11:43:01 PM : [  15 84 AC 1]       RR  31
Fri 03/13/2015 11:43:06 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 11 FF
Fri 03/13/2015 11:43:06 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 11 FF 06          LTONRR (FF)
Fri 03/13/2015 11:43:06 PM : [iNST-SRX    ] 02 50 15.84.AC 22.FF.0E 2B 11 FF    LTONRR (FF)
Fri 03/13/2015 11:43:06 PM : [std-Direct Ack] 15.84.AC-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Fri 03/13/2015 11:43:06 PM : [D2D EVENT   ] Event [15 84 AC 1] [sT] [255] uom=0 prec=-1
Fri 03/13/2015 11:43:06 PM : [  15 84 AC 1]       ST 255
Fri 03/13/2015 11:43:09 PM : [iNST-TX-I1  ] 02 62 15 84 AC 0F 13 00
Fri 03/13/2015 11:43:09 PM : [iNST-ACK    ] 02 62 15.84.AC 0F 13 00 06          LTOFFRR(00)
Fri 03/13/2015 11:43:13 PM : [D2D EVENT   ] Event [15 84 AC 1] [ERR] [1] uom=0 prec=-1
Fri 03/13/2015 11:43:13 PM : [  15 84 AC 1]      ERR   1
Comm shows good until Off command failed to get any response from device.  That usually means a load is causing noise when turned On.
What type load and can a new/different  load be used?
Wow...thanks for the ridiculously quick response. You're right! The switches controlled an outlet that had about 18 feet total of LEDs lighting plugged into them. Once I unplugged the LEDs (which have a transformer) and plugged in a simple battery charger, it worked.
So is there something I could add to make the LEDs work properly?
What's interesting is that I have the exact same setup on another switch about 15' away and it works fine. And like I said, this has been working great since I originally installed.
You can try a FilterLinc plugged into Outlet with LEDs plugged into filtered leg of FilterLinc.  Depends on the amount of interference being generated.   It is not uncommon for LEDs  and CFLs to start generating interference over time.
Ok. I will pick a FilterLinc for my LEDs.
Follow up question.
I now have the LEDs unplugged. I have a 2476D Dimmer (15.71.45) that controls a light. I can turn it on/off at the switch. But have inconsistent control of it via the Console. Thoughts on that? I can't unplug the light!
Sat 03/14/2015 12:45:34 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 13 00
Sat 03/14/2015 12:45:34 AM : [iNST-ACK    ] 02 62 15.71.45 0F 13 00 06          LTOFFRR(00)
Sat 03/14/2015 12:45:35 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 13 00    LTOFFRR(00)
Sat 03/14/2015 12:45:35 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:45:35 AM : [D2D EVENT   ] Event [15 71 45 1] [ERR] [0] uom=0 prec=-1
Sat 03/14/2015 12:45:35 AM : [  15 71 45 1]      ERR   0
Sat 03/14/2015 12:45:35 AM : [D2D EVENT   ] Event [15 71 45 1] [sT] [0] uom=0 prec=-1
Sat 03/14/2015 12:45:35 AM : [  15 71 45 1]       ST   0
Sat 03/14/2015 12:45:38 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 11 00
Sat 03/14/2015 12:45:38 AM : [iNST-ACK    ] 02 62 15.71.45 0F 11 00 06          LTONRR (00)
Sat 03/14/2015 12:45:38 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 11 00    LTONRR (00)
Sat 03/14/2015 12:45:38 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:45:45 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 11 00
Sat 03/14/2015 12:45:45 AM : [iNST-ACK    ] 02 62 15.71.45 0F 11 00 06          LTONRR (00)
Sat 03/14/2015 12:45:45 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 11 00    LTONRR (00)
Sat 03/14/2015 12:45:45 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:45:59 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 13 00
Sat 03/14/2015 12:45:59 AM : [iNST-ACK    ] 02 62 15.71.45 0F 13 00 06          LTOFFRR(00)
Sat 03/14/2015 12:46:00 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 13 00    LTOFFRR(00)
Sat 03/14/2015 12:46:00 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:46:03 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 11 00
Sat 03/14/2015 12:46:03 AM : [iNST-ACK    ] 02 62 15.71.45 0F 11 00 06          LTONRR (00)
Sat 03/14/2015 12:46:03 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 11 00    LTONRR (00)
Sat 03/14/2015 12:46:03 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:46:56 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 11 00
Sat 03/14/2015 12:46:56 AM : [iNST-ACK    ] 02 62 15.71.45 0F 11 00 06          LTONRR (00)
Sat 03/14/2015 12:46:56 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 11 00    LTONRR (00)
Sat 03/14/2015 12:46:56 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:46:58 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 13 00
Sat 03/14/2015 12:46:58 AM : [iNST-ACK    ] 02 62 15.71.45 0F 13 00 06          LTOFFRR(00)
Sat 03/14/2015 12:46:59 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 13 00    LTOFFRR(00)
Sat 03/14/2015 12:46:59 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:47:39 AM : Setting Time From NTP
Sat 03/14/2015 12:50:38 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 11 00
Sat 03/14/2015 12:50:38 AM : [iNST-ACK    ] 02 62 15.71.45 0F 11 00 06          LTONRR (00)
Sat 03/14/2015 12:50:38 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 11 00    LTONRR (00)
Sat 03/14/2015 12:50:38 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 12:50:40 AM : [iNST-TX-I1  ] 02 62 15 71 45 0F 13 00
Sat 03/14/2015 12:50:40 AM : [iNST-ACK    ] 02 62 15.71.45 0F 13 00 06          LTOFFRR(00)
Sat 03/14/2015 12:50:40 AM : [iNST-SRX    ] 02 50 15.71.45 22.FF.0E 2B 13 00    LTOFFRR(00)
Sat 03/14/2015 12:50:40 AM : [std-Direct Ack] 15.71.45-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
It appears the Local On Level is set to 0% On which is of course Off.
This is what an On should look like. with the Local On Level set to 100%
Sat 03/14/2015 01:21:07 AM : [iNST-TX-I1  ] 02 62 1D 23 6B 0F 11 FF
Sat 03/14/2015 01:21:07 AM : [iNST-ACK    ] 02 62 1D.23.6B 0F 11 FF 06          LTONRR (FF)
Sat 03/14/2015 01:21:08 AM : [iNST-SRX    ] 02 50 1D.23.6B 22.80.0B 2B 11 FF    LTONRR (FF)
Sat 03/14/2015 01:21:08 AM : [std-Direct Ack] 1D.23.6B-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 03/14/2015 01:21:08 AM : [D2D EVENT   ] Event [1D 23 6B 1] [sT] [255] uom=0 prec=-1
Sat 03/14/2015 01:21:08 AM : [  1D 23 6B 1]       ST 255
The On being issued has a 0% Local On Level
The paddle turns the load On as it is not possible to have the On paddle turn the load Off, even with a 0% Local On Level
Check the On Level (Applied Locally) field
Sorry, I do not know.   The state of the device after pressing On paddle did not match what the ISY thought it should have been but I get no Red ! on 4.2.28.
