March 14, 201511 yr I recently purchased and installed the zwave module into my isy994i. I have a few zigbee compatible lights bulbs that i would like to install and use as extenders. Will the isy994i with the zwave module installed controlled these lights? Do I need to install a zigbee module (if available)?
March 14, 201511 yr ZWave module does not control ZigBee device. The 994i accepts either the ZWave or ZigBee module, not both at the same time.
March 15, 201511 yr Also to note Zigbee has several different protocols. One of which is energy, HA, etc. So even if you did have Zigbee hardware it would not control the light bulbs. As far as I am aware the current energy module and Zigbee stack only controls TSTAT's and Insteon devices based on ADR load responses. It was asked many years ago to expand the capability of the Zigbee support. Thus far years later nothing has come out of this or any movement in development. Perhaps once alpha / beta 5.XX is released and major bugs are fleshed out. More time and resources can be dedicated to this area. Ideals are peaceful - History is violent
March 16, 201511 yr If you pick up a HueHub, you can use that and the ISY Network module to control your Zigbee Lights (Assuming they are compatible with Hue which many seem to be). -Xathros
