March 21, 201511 yr I have upgraded and then factory reset the Zwave module. Devices will not pair to the ISY on the older ZWAVE firmware, but do on the new. I see a success pair in the logs, but no devices show up in my network in the GUI. Am I missing something? I did not purchase the Insteon PLM as a I did not have an immediate need for insteon devices. I do have an existing network with Smartthings where these devices were successfully paired before and removed properly before pairing with the ISY. ZWAVE module FW: 4.55. Logs below: Sat 03/21/2015 10:14:29 AM : [ZWAVE-FW ] Version 4.55 Static Controller Library Sat 03/21/2015 10:14:29 AM : Z-WAVE FIRMWARE UPGRADE SUCCESSFULLY COMPLETED Sat 03/21/2015 10:15:13 AM : Listening for Z-Wave devices to add to the network Sat 03/21/2015 10:16:45 AM : Adding Z-Wave devices stopped Sat 03/21/2015 10:16:53 AM : Listening for Z-Wave devices to remove from the network Sat 03/21/2015 10:16:57 AM : Removing Z-Wave devices stopped Sat 03/21/2015 10:17:16 AM : Listening for Z-Wave devices to remove from the network Sat 03/21/2015 10:17:19 AM : Removing Z-Wave devices stopped Sat 03/21/2015 10:17:26 AM : Listening for Z-Wave devices to add to the network Sat 03/21/2015 10:17:29 AM : Z-Wave device detected, retrieving info 2 Sat 03/21/2015 10:17:30 AM : Z-Wave device detected, retrieving info 3 Sat 03/21/2015 10:17:30 AM : Z-Wave device detected, retrieving info 5 Sat 03/21/2015 10:17:30 AM : Adding Z-Wave devices stopped Sat 03/21/2015 10:17:31 AM : Device 2 of type 4.17.1 included into Z-Wave network Sat 03/21/2015 10:17:31 AM : Adding ISY node(s) for new Z-Wave device 2 type 4.17.1 Sat 03/21/2015 10:17:31 AM : [ZWAVE-ADD-NODE ] Add device: mfg 0063.4457.3230, basic=0x04 gen=0x11 spec=0x01 Sat 03/21/2015 10:18:28 AM : Listening for Z-Wave devices to add to the network Sat 03/21/2015 10:18:31 AM : Z-Wave device detected, retrieving info 2 Sat 03/21/2015 10:18:31 AM : Z-Wave device detected, retrieving info 3 Sat 03/21/2015 10:18:31 AM : Z-Wave device detected, retrieving info 5 Sat 03/21/2015 10:18:32 AM : Adding Z-Wave devices stopped Sat 03/21/2015 10:18:32 AM : Device 3 of type 4.17.1 included into Z-Wave network Sat 03/21/2015 10:18:32 AM : Adding ISY node(s) for new Z-Wave device 3 type 4.17.1 Sat 03/21/2015 10:18:32 AM : [ZWAVE-ADD-NODE ] Add device: mfg 0063.4457.3230, basic=0x04 gen=0x11 spec=0x01 Sat 03/21/2015 10:28:18 AM : [ZWAVE-TX ] [01030015E9] Sat 03/21/2015 10:28:18 AM : [ZWAVE-RX ] ACK Sat 03/21/2015 10:28:18 AM : [ZWAVE-RX ] [011001155A2D5761]... Sat 03/21/2015 10:28:18 AM : [ZWAVE-TX ] ACK Sat 03/21/2015 10:28:18 AM : [ZWAVE-FW ] Version 4.55 Static Controller Library Sat 03/21/2015 10:28:18 AM : [uZW-CMD 17 ] Get Dongle Version
March 21, 201511 yr There is no need generally to factory reset the Z wave dongle. You may not be able to add devices because they are out of synchronization. Run a Z wave synchronization to compare the database in the ISY to the dongle. They should all show up again, remove the ones that you want or re-add devices as necessary. Sorry for brevity - posted using mobile Tapatalk
March 22, 201511 yr Author Thanks for the feedback. I ran a sync on all nodes and still no luck. I healed the network as well. Any other suggestions?
March 22, 201511 yr Author I am using GE Jasco Dimmer switches. Are these supported? The WIKI doesn't mention them.
March 22, 201511 yr Can you please fill out this form? The information will be sent to support to help troubleshoot. http://www.universal-devices.com/device-support/ Sorry for brevity - posted using mobile Tapatalk
March 23, 201511 yr I am using GE Jasco Dimmer switches. Are these supported? The WIKI doesn't mention them. I'm using a couple of these. They work fine.
February 18, 201610 yr Hello, What was the solution here? I am having the same issue. Using Monoprice plugin Z-Wave Light Dimmers (PID:11994) ISY994i/zWave Dongle Firmware/UI; v4.3.26 ZWave Version: 4.55 Bootloader: 1.03 Library: Static Edited February 18, 201610 yr by st1ckyb1t
February 18, 201610 yr Hi st1ckyb1t, Please make sure to Exclude it first. Do you have other Z-Wave devices that work? With kind regards, Michel
February 19, 201610 yr Michel, Thanks for the reply. I just came home with a Leviton Scene-Capable Plugin Lamp Dimming Module (Cat # DZPD3), tried to add it by removing it, then adding it a few times. I still see the Event Viewer details (shown below), but no item shows up in the list. How do I wipe everything out, and start over? Thanks! Thu 02/18/2016 20:42:01 : Listening for Z-Wave devices to remove from the networkThu 02/18/2016 20:42:10 : Removing Z-Wave devices stoppedThu 02/18/2016 20:42:10 : Device 7 excluded from Z-Wave networkThu 02/18/2016 20:42:22 : Listening for Z-Wave devices to add to the networkThu 02/18/2016 20:42:27 : Z-Wave device detected, retrieving info 2Thu 02/18/2016 20:42:27 : Z-Wave device detected, retrieving info 3Thu 02/18/2016 20:42:28 : Z-Wave device detected, retrieving info 5Thu 02/18/2016 20:42:28 : Adding Z-Wave devices stoppedThu 02/18/2016 20:42:29 : Device 8 of type 4.17.4 included into Z-Wave networkThu 02/18/2016 20:42:29 : Adding ISY node(s) for new Z-Wave device 8 type 4.17.4Thu 02/18/2016 20:42:29 : [ZWAVE-ADD-NODE ] Add device: mfg 001D.1902.0334, basic=0x04 gen=0x11 spec=0x04
February 19, 201610 yr Hi st1ckyb1t, It seems to have succeeded. Can you please let me know the model number of your ISY and the number of devices, nodes, and folders you have (approximate)? With kind regards, Michel
February 19, 201610 yr Michel, It is an ISY994i, with a very basic setup; just trying to get a few devices registered and functioning. uuid:00:21:b9:00:f9:fe Firmware/UI: Insteon_UD994 v.4.3.26 Product: ISY 994i(1120)-- OpenADR (21010) -- Z-Wave (21100) 2 devices: LampLinc DimmersTried to add 2 Monoprice z-Wave Plug-in Dimmers, and 1 Leviton Scene-Capable Plugin Lamp Dimming Module (Cat # DZPD3), Folders are: Network -ISY --LD1 --LD2 -Auto DR Z-Wave Info: ZWave Version: 4.55 Bootloader: 1.03 Library: Static
February 19, 201610 yr Hi st1ckyb1t, This is very very odd. Can you please: 1. Open the Event Viewer, change level to 3 2. Go to Z-Wave | Tools | Synchronize Nodes | All 3. Paste the output of Event Viewer. With kid regards, Michel
February 19, 201610 yr Michel, Fri 02/19/2016 11:02:54 : [ZWAVE-FW ] Version 4.55 Static Controller LibraryFri 02/19/2016 11:14:43 : [uZW-CMD 10 ] Sync Full : All
February 19, 201610 yr Michel, Yes, correct. I just also tried it with Level 2, same result, and Level 1, 0 entries in log.
February 21, 201610 yr Hi st1ckyb1t, In that case, there's nothing in your dongle. If you don't have too many devices, what you might want to try: 1. Z-Wave | Advanced | Factory reset Z-Wave dongle 2. Z-Wave | Tools | Synchronize nodes | All (this should remove all your Z-Wave devices the Admin Console) 3. Z-Wave | Exclude ... remove the Z-Wave device 4. Z-Wave } Include ... include the Z-Wave device In all cases, please have Event Viewer open on Level 3. Once done, please save the contents of the Event Viewer and send to support@universal-devices.com and have a link to this forum post. With kind regards, Michel
February 21, 201610 yr Michel, Thanks for the tips. How can I start over, fresh, without any former settings? I am concerned that errors such as the [File Open} failures (in bold, below) are indicative of part of my problem. In any case, below is the log capture from your requested actions: Sun 02/21/2016 12:45:34 : [ZWAVE ] Factory Resetting Z-Wave dongleSun 02/21/2016 12:45:34 : [ZWAVE ] Setting our application node infoSun 02/21/2016 12:45:34 : [ZWAVE-TX ] [0109000303020002]...Sun 02/21/2016 12:45:34 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:34 : [ZWAVE-TX ] [010400420BB2]Sun 02/21/2016 12:45:34 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-RX ] [010400420BB2]Sun 02/21/2016 12:45:35 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-TX ] [01030020DC]Sun 02/21/2016 12:45:35 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-RX ] [01080120E4AD6A4B]...Sun 02/21/2016 12:45:35 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-TX ] [01030002FE]Sun 02/21/2016 12:45:35 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-RX ] [0125010205001D01]...Sun 02/21/2016 12:45:35 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-TX ] [01030005F9]Sun 02/21/2016 12:45:35 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:35 : [ZWAVE-RX ] [0104010528D7]Sun 02/21/2016 12:45:35 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-TX ] [010600221408EE29]Sun 02/21/2016 12:45:36 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-RX ] [0104012202DA]Sun 02/21/2016 12:45:36 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-TX ] [0106002214092DEB]Sun 02/21/2016 12:45:36 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-RX ] [0104012202DA]Sun 02/21/2016 12:45:36 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-TX ] [01060022140AFF3A]Sun 02/21/2016 12:45:36 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-RX ] [0104012202DA]Sun 02/21/2016 12:45:36 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-TX ] [01060022140B76B2]Sun 02/21/2016 12:45:36 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-RX ] [0104012202DA]Sun 02/21/2016 12:45:36 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-TX ] [01060022140C02C1]Sun 02/21/2016 12:45:36 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:36 : [ZWAVE-RX ] [0104012201D9]Sun 02/21/2016 12:45:36 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-TX ] [01030020DC]Sun 02/21/2016 12:45:37 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-RX ] [01080120EE2DFF76]...Sun 02/21/2016 12:45:37 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-TX ] [01030002FE]Sun 02/21/2016 12:45:37 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-RX ] [0125010205001D01]...Sun 02/21/2016 12:45:37 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-TX ] [01030005F9]Sun 02/21/2016 12:45:37 : [ZWAVE-RX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE-RX ] [0104010528D7]Sun 02/21/2016 12:45:37 : [ZWAVE-TX ] ACKSun 02/21/2016 12:45:37 : [ZWAVE ] Factory Reset of Z-Wave dongle completeSun 02/21/2016 12:45:37 : [uZW-CMD 14 ] Factory Reset DongleSun 02/21/2016 12:46:04 : [uZW-CMD 10 ] Sync Full : AllSun 02/21/2016 12:47:30 : [ZWAVE-TX-NR ] [0105004B010CBC]Sun 02/21/2016 12:47:30 : [uZW-CMD 2 ] Start ExcludeSun 02/21/2016 12:47:30 : [ZWAVE-RX ] ACKSun 02/21/2016 12:47:30 : [ZWAVE-RX ] [0107004B0C010000]...Sun 02/21/2016 12:47:30 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:30 : Listening for Z-Wave devices to remove from the networkSun 02/21/2016 12:47:39 : [ZWAVE-RX ] [0107004B0C020000]...Sun 02/21/2016 12:47:39 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:39 : [ZWAVE-RX ] [0113004B0C03000C]...Sun 02/21/2016 12:47:39 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:39 : [ZWAVE-RX ] [0113004B0C06000C]...Sun 02/21/2016 12:47:39 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:39 : Removing Z-Wave devices stoppedSun 02/21/2016 12:47:39 : [ZWAVE-TX ] [01030020DC]Sun 02/21/2016 12:47:39 : [ZWAVE-RX ] ACKSun 02/21/2016 12:47:39 : [ZWAVE-RX ] [01080120EE2DFF76]...Sun 02/21/2016 12:47:39 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:39 : [ZWAVE-TX ] [01030002FE]Sun 02/21/2016 12:47:39 : [ZWAVE-RX ] ACKSun 02/21/2016 12:47:39 : [ZWAVE-RX ] [0125010205001D01]...Sun 02/21/2016 12:47:39 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:40 : [ZWAVE-TX ] [01030005F9]Sun 02/21/2016 12:47:40 : [ZWAVE-RX ] ACKSun 02/21/2016 12:47:40 : [ZWAVE-RX ] [0104010528D7]Sun 02/21/2016 12:47:40 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:54 : [ZWAVE-TX-NR ] [0105004AC10D7C]Sun 02/21/2016 12:47:54 : [uZW-CMD 1 ] Start IncludeSun 02/21/2016 12:47:54 : [ZWAVE-RX ] ACKSun 02/21/2016 12:47:54 : [ZWAVE-RX ] [0107004A0D010000]...Sun 02/21/2016 12:47:54 : [ZWAVE-TX ] ACKSun 02/21/2016 12:47:54 : Listening for Z-Wave devices to add to the networkSun 02/21/2016 12:48:00 : [ZWAVE-RX ] [0107004A0D020000]...Sun 02/21/2016 12:48:00 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:00 : Z-Wave device detected, retrieving info 2Sun 02/21/2016 12:48:00 : [ZWAVE-RX ] [0113004A0D03020C]...Sun 02/21/2016 12:48:00 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:00 : Z-Wave device detected, retrieving info 3Sun 02/21/2016 12:48:00 : [ZWAVE-RX ] [0107004A0D050200]...Sun 02/21/2016 12:48:00 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:00 : Z-Wave device detected, retrieving info 5Sun 02/21/2016 12:48:01 : [ZWAVE-TX ] [0105004A850E3B]Sun 02/21/2016 12:48:01 : [ZWAVE-RX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-RX ] [0107004A0E060200]...Sun 02/21/2016 12:48:01 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:01 : Adding Z-Wave devices stoppedSun 02/21/2016 12:48:01 : [ZWAVE-TX ] [01030020DC]Sun 02/21/2016 12:48:01 : [ZWAVE-RX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-RX ] [01080120EE2DFF76]...Sun 02/21/2016 12:48:01 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-TX ] [01030002FE]Sun 02/21/2016 12:48:01 : [ZWAVE-RX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-RX ] [0125010205001D03]...Sun 02/21/2016 12:48:01 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-TX ] [01030005F9]Sun 02/21/2016 12:48:01 : [ZWAVE-RX ] ACKSun 02/21/2016 12:48:01 : [ZWAVE-RX ] [0104010508F7]Sun 02/21/2016 12:48:01 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:01 : Device 2 of type 4.17.4 included into Z-Wave networkSun 02/21/2016 12:48:01 : [ZWAVE-TX ] [0109001302027204]...Sun 02/21/2016 12:48:02 : [ZWAVE-RX ] ACKSun 02/21/2016 12:48:02 : [ZWAVE-RX ] [0104011301E8]Sun 02/21/2016 12:48:02 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:02 : [ZWAVE-RX ] [010500130F00E6]Sun 02/21/2016 12:48:02 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:02 : [ZWAVE-RX ] [010E000400020872]...Sun 02/21/2016 12:48:02 : [ZWAVE-TX ] ACKSun 02/21/2016 12:48:02 : Adding ISY node(s) for new Z-Wave device 2 type 4.17.4Sun 02/21/2016 12:48:02 : [ZWAVE-ADD-NODE ] Add device: mfg 001D.1902.0334, basic=0x04 gen=0x11 spec=0x04Sun 02/21/2016 12:48:37 : [FileOpen ] Open failed for [/CONF/ELK.CNF] ®Sun 02/21/2016 12:48:38 : [FileOpen ] Open failed for [/CONF/ELK.CNF] ®Sun 02/21/2016 12:48:55 : Setting Time From NTP Edited February 21, 201610 yr by st1ckyb1t
February 21, 201610 yr Hi st1ckyb1t, Please do NOT factory reset. The error you see is 100% normal and completely benign. I noticed that the device got included. Can you control it now? With kind regards, Michel
February 21, 201610 yr Michel, Ok, understand...was just curious if that might help resolve things. No controllability yet. Below is the device tree; same as it was before: Network -ISY --LD1 --LD2 -Auto DR Edited February 21, 201610 yr by st1ckyb1t
February 21, 201610 yr Michel, LD1 and LD2 are both Insteon LampLinc Dual-Band Dimmers, model 2457D2.
February 21, 201610 yr Hi st1ckyb1t , I think it's best to submit a ticket (links below) so that we can login to your computer and see what's causing the issue. With kind regards, Michel
