Does android lollipop work fine with mobilinc?
Depends on the version of your ISY (99 vs 994, PRO vs non-PRO and the specific firmware version).
With the latest ISY version, there should be no issue. The higher encryption though makes it a little sluggish to connect.
Seems to work with lollipop  ( TAB S )  with the latest, but slow on https.
MobilLinc does not work with the non pro 994i version on Lollipop.  Had to upgrade to the Pro version ($30) and then suffer with slow response with cell data connections.  I would just stick with KitKat.
It does work if you upgrade to the latest version - UDI made TLS the default for non-pro which solved this issue.
