zwave rest command for Yale
I'm creating a lock/unlock command to use in iRules
Here is what I created and its not working.
Any suggestions?
/rest/nodes/ZW011_1/cmd/DON
When I use this in my browser I get a response of 404 (I'm assuming that's an error message)
Here is what I'm using for unlock.
/rest/nodes/ZW011_1/cmd/DOF
Thank you
Edited by Envirogreen
Does the Unlock work?
-Xathros
So I forgot that I triggered the lock unlock by sending a message from irule to elk (f3)
Then in ISY i have a rule that locks unlocks based on elk f3 being pressed
The key item missing is a rest command to the ISY that queries the lock or unlock state of the Yale lock (that will let me determine the correct image in irule when I enter the page)
Thank you
Commands:
http://forum.universal-devices.com/topic/12373-lock-unlock-with-rest-interface/?p=101099
Status:
http://<ISYIP>/rest/status/<ZW_NODE>
OR
http://<ISYIP>/rest/nodes/<ZW_NODE> and look for:
Locked
<property id="ST" value="100" formatted="Locked" uom="11"/>
Unlocked
<property id="ST" value="0" formatted="Unlocked" uom="11"/>
Edited by PurdueGuy
Any suggestions to query status (is it locked/unlocked)?
I gave that answer previously, via a REST API command.
The ISY doesn't give blank responses that I know of.  Are you using Firefox or Chrome?
This command works for me:
http://192.168.1.56/rest/status/ZW021_1
