Ecolink Z-Wave Door/Window Sensor (DWZWAVE2-ECO) pairing with ISY-994i
Good evening,
may be do right click on the node>zwave>show info in event viewer>all
then look in the event viewer and you should see sensor_multilevel I think if it is a multisensor
cheers.
Okay doke -- good news is that it does not appear to be a multi-sensor.  Here's what I see
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ] ----------------------------------------------
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ] ZW030_1 uid=30 type=4.32.1 mid=330 tid=1 pid=2 model=0
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x30  V0  SENSOR_BINARY
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x71  V2  NOTIFICATION
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x72  V1  MANUFACTURER_SPECIFIC
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x86  V0  VERSION
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x85  V2  ASSOCIATION
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x84  V2  WAKE_UP
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x80  V0  BATTERY
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x70  V1  CONFIGURATION
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  xEF  V0  MARK
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -  x20  V0  BASIC
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ] Node  30 - Back Porch Gate Sensor has the following neighbors
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -          - Node   1 - _MiCaseVerde Controller
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node   2 - _REPEATER: Dining Room
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node   3 - _REPEATER: Office
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node   4 - _REPEATER: Sitting Room
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node   8 - Power Meter - Panel 1
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node   9 - _REPEATER: Mudroom
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    -          - Node  10 - Front Door Lock
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node  15 - Power Meter - Panel 2
Thu 01/07/2016 08:15:11 : [ZW-SHOW         ]    - Repeater - Node  20 - _REPEATER: Basement
Thu 01/07/2016 08:15:27 : [ZW-SHOW         ] Node  30 - Back Porch Gate Sensor cannot retrieve association groups
Thu 01/07/2016 08:15:27 : [ZW-SHOW         ] ----------------------------------------------
Does that shed any light on what might be up?
Gerry
Howdy,
Wanted to report back that it seems that it is NOT an ISY problem, per se (or at least I don't think so).
As I mentioned, in one of my houses, the ISY is the ZWave secondary.  In general, that hasn't been a problem with things being reported, but this seems like one that was.
I had a spare sensor and brought it to my other house where the ISY is the ZWave master and added it in.  It worked correctly (reporting changes as they happened).
When the exact same switch/unit was added to the primary controller at the first house, it appeared in the ISY, but would not receive any updates and not update after a poll/query either (even after the device was first "woken" up).
So not exactly sure why this device alone seems to not update when ISY is a ZWave secondary, but since it will work with it's a Primary, I have to believe this is some secondary controller weirdness and not the ISY.
Gerry
I have healed the ZWave network from it's primary and it hadn't helped.  This was the only device (out of about 20) that I added to the ISY with my older Vera3 acting as a the ZWave master that didn't show status changes as they happened. That includes other battery powered ZWave devices (locks and climate sensors).  All the rest worked great!
Gerry
