Java and Admin Console
Since I installed the admin console , updated Java 6 months ago it has functioned without a problem.
I have always started it from an desktop icon on windows 7
Yesterday it began acting strange, after clicking the icon there was a delay, then the JAVA logo appeared and a progress bar started running. After about 15 sec. the admin console finally came up. This happens now every time I run the admin console.
I have not changed anything or done any updates to explain the possible cause. I have rebooted win7 several times with same results.
Although it still works, the delay is getting very frustrating.
I would appreciate any suggestions on how I can get my admin console back the way it was.
Thanks Everyone
Don
Java 6? The latest Java 8.
Edited by stusviews
 I took Don's reply that he upgraded the Java application six months ago. But, I can see how it could be taken as he is running Java v6.  :mrgreen:
Grizzy
After Java was updated were the cached and installed java applications deleted and the Admin Console installed again so it would have the latest Java code?
I did not have Java prior to buying the ISY.
After reading install procedure, I installed Java 8 and then installed the admin console and everything was working fine. I did the original install about 6 months ago. I am using win7.
I have not seen anything else unusual with my computer.
Don
What does Help | About show for
Firmware
UI
Is the router updated automatically by the Internet provider?
No
Hi Grizzy,
If you are using our website URL (admin.jnlp), then every time you bring up ISY Finder, Java checks the date and certificate for all the files. If there are network issues or too much load on the server, then I can see there being a delay.
You can always use the Admin Console directly from ISY using your browser (http://isy/admin) and this should be quite fast.
Firmware
UI
No The router is not updated.
Firmware  v.4.2.15
UI              v.4.2.18
Hi Grizzy,
Hi Michel,
I tried the above link. It caused Java to do an upgrade to v8.40
Afterwards it was slower to load from the above link.
Loading from the desktop icon still displays Java and a progress bar and it still slow to start the admin console (now The Java Logo is blue, before it was a red logo)
Don
Hello Don,
This may not resolve the slow loading times but I did notice your firmware and UI levels were not the same.
Please clear the Java cache and select all check box's while doing so. Often times strange behavior is attributed to this one conflict.
Ideals are peaceful - History is violent
Hello Don,
 Hi Teken,
I cleared the cache and it deleted the ISY Icon on my desktop.  Is this expected ?
I reloaded the admin Console from the file I used on the original install. (Darn, can't remember where I got it, but at least I saved it after the install)
Every thing has returned to normal :-))
Checked UI version and nothing changed there, so I'm not sure what happened or caused the problem .. gremlins ?
Thank You All for your help.
Don
 Hi Teken,
Don
If you use another (older) link for a previous Beta firmware this too can cause untold issues. The UI / Firmware in the *About* in all cases should match and be identical. This single conflict has in the past resolved many random issues not explainable.
If you're in doubt and the *About* still indicates a conflict with what you actually have. I would humbly suggest you perform the upgrade again and than clear the java cache including all check box's.
At that time you will use the most current link that is associated to that firmware release to access the Admin Console.
Are the older versions still available ? Where ?
From reports UI has a good record on new releases, so I feel good there. I kinda believe if it's not broke don,t fix it.
I'm sort of slow to jump at every new thing that emerges from a rapid changing technology. Gee I still use a DOS & win95 not to mention the TRS80 MOD III
Although I,m really excited and waiting to see the release of version 5. ( hint, hint )
I see you point and agree.
Don
here
I use DOS, but I've upgraded to XP, both 32 and 64 B)
BTW, 8.1, too, both 32 and 64
